![]() | Home > Technical (L322) > Bottom ball joint nightmare |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 215 ![]() ![]() ![]() |
I'm in the process of replacing the front wheel bearings, both arms and all other bits, I managed to get the driveshaft loosened, removed steering arm, and then removed the bolts holding the arms to the sub front, took it to my handy press and pressed everything out. Even with a press it's a job to get it all to move, some fair noise when things come loose, the main problem is getting things solid and level enough to put force to the various bits out, getting the driveshaft back in is still a work of violence and persuasion though, I do like your hub puller, better than a couple of big hammers..
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 538 ![]() ![]() |
EDITED - Ignore this post, I'm getting mixed up and have deleted advice to use a universal sleeve press kit.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
Would you be able to post a link to the tool? Kevin 2012 L322 Westminster 4.4 TDV8 1999 P38A 4.0 SE - Sold |
This is the one I have, https://www.garagediagnostictools.co.uk/pr...ww-1017ww/
Thanks for that last bit of advise Phoenix |
If you can't drill & tap, I've known people put a big pair of mole grips around the driveshaft and beat them with a copper hammer whilst rotating the driveshaft back & forth, I've seen one tech build it all back up and run the engine in gear (all the wheels off the floor, obviously!) whilst tapping the side of the CV joint with a small(ish) hammer, took a few minutes but worked. |
Many thanks, good to know what works and worth the investment👍 Kevin
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 402 ![]() ![]() ![]() |
Yes, they are a tight and can be a real pain. I also get my Dremel out and clean up the splines - you can also use a small triangular metal file Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
I was recommended this tool for refitting the shaft to the hub, which I have bought but not used yet.
GrunterNI Member Since: 30 Oct 2020 Location: Co Down Posts: 48 ![]() ![]() ![]() |
So gents, it's back to a nightmare yet again!! It would seem that the CV joint and I are at an impasse |
The best penetrating fluid for that sort of job is 1:1 brake fluid & Acetone.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
My experience of such jobs has led me to the conclusion that if anything like this needs replacing, off to my local Indy it goes.
