Home > In Car Electronics (L405) > L405 2016 vogue android upgrade
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
I am in the process of purchasing an android upgrade for the infotainment unit
It sounds a bit of daft question but I will as anyway
I have DAB radio, am I therefore correct in assuming I have a DAB antenna which would connect to the new android unit. I need to establish this before ordering the android unit
Can anyone confirm this or point me in the right direction to find out, I have not removed the existing unit from the car
also is it absolutely necessary to install the GPS aerial which is supplied with the unit ?
any info would greatly received various other LR's this one is still the best
Post #676489 26th Oct 2023 1:08pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
From when I was looking into doing this upgrade it seemed that as long as you used the GPS splitter wire then you didn’t need to install an additional GPS antenna as the new unit would use the existing car antenna. The DAB aerial simply unplugged from the original unit and into the new unit - simple as that.
It was the 4G antenna that was required as there is no way of linking into the inbuilt 4G antenna from what I understand.
Post #676538 26th Oct 2023 10:39pm
philbathurst
thanks for info, still searching think i need to remove the unit to confirm DAB connection various other LR's this one is still the best
Post #676553 27th Oct 2023 12:50am
I've not watched it, but the details you need might well be in this video -
Post #676583 27th Oct 2023 11:14am
philbathurst
thanks
watched that and all of theirs and other videos on the tube, as they very pedantic about explaining every thing very clearly. I wasn't able able to find out
I'm fairly sure that I won't be absolutely sure until I remove the existing unit
the logic is that as I have DAB radio it must be connected
a simple solution is to purchase DAB antenna and dongle with the android unit (£50), which I understand will upgrade to DAB plus
that should solve the issue, didn't think it was going to be so difficult to find out
as an aside I can't believe how technically tricky it is to decide on which android unit to choose various other LR's this one is still the best
Post #676591 27th Oct 2023 12:16pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
been looking at getting one myself but cant decide on which one and also the wife doesn't like the idea of the microphone been stuck somewhere was thinking it could be connected to the cars microphone somehow ?,and going to get a gps splitter to use the cars gps
Post #703859 6th Nov 2024 7:42am
