Home > Maintenance & Mods (L322) > Starter motor
Jaysto
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Starter motor
2012 4.4 Westminster,starter motor stuck ,how do I get it out of park so it can be recovered to a garage
Post #676525 26th Oct 2023 9:28pm
Phoenix
Ignition on, foot on brake, move gearshift.
Post #676526 26th Oct 2023 9:31pm
Jaysto
Could if the gearshift pops up …it’s a 2012
Post #676528 26th Oct 2023 9:49pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Have a look in cup holder, take out mat should be a red lever to release gearbox. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #676533 26th Oct 2023 10:26pm
DrRob
Workshop Manual:
To disengage the park lock: Open the cubby box lid and the drinks holder lid. Remove the trim panel from between the drinks
holder and the cubby box. Rotate the locking mechanism of the emergency park release lever 90 degrees counterclockwise.
Apply the footbrake, pull the operating lever upwards and ensure it locks in the vertical position. Raising the operating lever
causes the emergency park release cable to rotate the park interlock lever on the transmission, which disengages the parking
pawl and engages neutral. This allows the vehicle to freewheel.
To re-engage the park lock: Hold the strap on the operating lever, release the latch and lower the operating lever to the
horizontal position. Lock the operating lever by turning the locking mechanism 90 degrees clockwise. Install the trim panel.
Close the cubby box lid and the drinks holder lid
If handbrake then there is a pull wire behind the offside (drivers UK) side boot panel. Don't confuse it with the fuel filler flap one. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #676560 27th Oct 2023 8:27am
