Home > Technical (L405) > Coolant leak
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Coolant leak
I have a minor coolant leak on my 4.4 SDV8 SE. Apparently it's a top hose that is leaking and the part, which was a single hose, has now been superseded by 3 hoses. I have been quoted over £350 for the replacement hoses which seems a bit expensive to me. Anyone know which hoses they are referring to?
TIA
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #660902 2nd Apr 2023 9:21am
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Can you try and look to see which one is leaking. Mine sprung a leak from the small vent pipe into the top left of the rad, when looking at the car from the front 2016 AB SDV8 Barolo black - Sadly sold
1995 RR Classic - Ex Police car - Now Sold
1994 RR 4.2 LSE - Long gone
Post #661022 4th Apr 2023 11:34am
IGP
Unfortunately this is what was reported by the garage. I was hoping someone would know which hoses they are talking about.
Post #661030 4th Apr 2023 2:09pm
IGP
Got a bit more info from the garage. Apparently it's the top radiator hose that leaking but, unfortunately the latest version from Land Rover will only fit in conjunction with the other 2 hoses. Not sure what the other two hoses are.
Post #661054 4th Apr 2023 4:55pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
If it is the hose I think it is, I have heard of an independent fixing this with a simple o ring of the right size rather than replacing the whole hose assembly. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #661058 4th Apr 2023 5:34pm
IGP
OK the part number is LR034643 which has been superseded by LRO80118+LRO80119 and LRO88120
Duckworths are showing the original part number at £25 but the new parts are coming at near £300!!! 2013 Vogue SE SDV8
Post #661063 4th Apr 2023 5:58pm
IGP
OK got the leak fixed. It turns out the leak was in the top hose where it connected to the Radiator. As I had new brake pads all round they did not charge me for fixing it. They just fitted a new seal inside the hose and all good.
This was a much better option than the so called 4x4 LR Specialists who wanted to charge me over £600 to replace the coolant pipes.
I certainly won't be going back to the parts swappers specialist.
Post #664507 19th May 2023 4:46pm
fisha
Good stuff. Whilst the hoses may be reportedly brittle, the bulk of them are sealed by the o rings and it’s only them that need replaced to resell stuff. Seems mad that LR themselves don’t list the rings seperatey. V8 or else ...
Post #664515 19th May 2023 6:14pm
Shocked Shocked Shocked
Post #664570 20th May 2023 11:58pm
IGP
Just to clarify, the 4x4 LR Specialist was not Cam-Tech-Craig. 2013 Vogue SE SDV8
Post #664697 22nd May 2023 3:26pm
My Shocked Shocked Shocked reaction was that of shock that some garages still take the living pi55 out of unsuspecting customers! But thank you for clarification sir Bow down Thumbs Up
Post #664703 22nd May 2023 3:56pm
Sonearly
I have a small leak from the top breather pipe, left hand side top, before I break it could someone tell me how to take off, is it a case of just prising each side ? If someone knows the “O” ring size would be even better.
Post #676772 29th Oct 2023 1:58pm
