Home > Technical (L322) > Range Rover L322 2011 4.4TDV8 knocking/Rattling
Page 2 of 3 <123>
Defender Fun
United Kingdom 2008 Range Rover Vogue TDV8 Bonatti Grey
Any thoughts on the above?
Post #676790 29th Oct 2023 6:04pm
DrRob
The workshop manual in the Wiki is downloadable.
It has a full chapter on DTC = diagnostic trouble codes. It’s long but comprehensive. That’s where I would start Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676792 29th Oct 2023 6:50pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Does the noise sound like a tapping around the top left of the engine that changes as with the revs.?
If so, it's most likely the big end going.
Post #676820 30th Oct 2023 10:00am
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Big ends run on the crankshaft journal’s at the bottom of the engine, so it’s unlikely to be heard at the top end
Post #676825 30th Oct 2023 11:21am
Mike Edwards
The last two L322s (4.4 TDV8) with a tapping that sounded cam chain-ish, loudest in the top left front section of the engine, had knackered big ends. the loudest one needed crank and rods, the other we caught early enough to just need new bearings.
Post #676832 30th Oct 2023 11:34am
Defender Fun
Thanks for the replies.
As advised I’ve referred to the manual and found the fault code and resolution, hopefully I can get a dry spell and give it a go.
Anyone had starting issues from the lift pump relay?
Till I get that fixed I can’t turn it on to get a video to upload of the sound. I do hope it not that deep into the engine though!
Post #676955 31st Oct 2023 10:28pm
Defender Fun
Post #676956 31st Oct 2023 10:28pm
Defender Fun
Please find the below video, got some time to go out today and work on her. The fuel lift pump issue has gone must have been due to battery voltage?
I have found today the sound is coming from the passenger side. It is a bit more high pitch than what It sounds in the video.
This is recorded with both belts off the car.
Any recommendations would be great
Please let me know if you can open the links below I’m not sure how to upload videos to the forum
https://share.icloud.com/photos/0ae1sHJk5xE3MPc2UczfYk-gA
https://share.icloud.com/photos/0e0mwmjj56JLh0qvzH786dE7A
Post #677343 5th Nov 2023 6:27pm
Defender Fun
Also only getting the two below faults which I think are simply because the fan belts are disconnected.
Post #677344 5th Nov 2023 6:30pm
pjw888
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Hi there, by no means a 4.4 expert but I'm ex motor industry tech with 40+ years of enginw work Etc. Difficult from just a video but to me, seems very top end, hydraulic lifter type noise. My suggestions...........by a cheap stethoscope and safely test near n/s cam cover area. If it's there, the steth with pick this up and allow you to pin point a spcific area. Does it get worse hot or cold? Having listened a few times, I'd always stick to basics. Get the oil out, what does it look like. Check the oil filter, replace for best practice.
Over the years, I've seen many assumptions of major failure components when in reality, it's often the most simple repair process which works. I'm not sure how I can contact you directly but I'm more than willing to help and advise. Please let us all klnow the outcome.
Post #677350 5th Nov 2023 7:37pm
Defender Fun
Thank you for your reply, I do have a stethoscope (cheap one from eBay from a while ago) but don’t seem to be picking up anything that sounds peculiar.
I will drain the oil (hopefully tomorrow) and report my findings. Providing I don’t find anything abnormal shall I refill or do you advise any other testing?
Your support would be great! I’m technically minded (as hobby I do a lot of mechanical work even rebuilt a 2 door Range Rover and series 2 both of the engines I rebuilt) but with these later engines I need some guidance due to so much components and worst the tight engine bay!
I’ll PM my contact details
Post #677360 5th Nov 2023 8:36pm
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
If your draining oil is it worth sending a sample for analysis. God forbid you have a bearing failing or similar but it could be picked up by oil analysis. It doesn’t sound heavy enough for a big end etc to me though. Have you looked at injector values with engine idling using diagnostics? There may be an odd one out which may lead to a particular cylinder to investigate. It’s possible an injector has “hosed” and caused a piston skirt to pick up ?
This of course wouldn’t be good news
Wish you all the luck with this & please keep us updated
QT
Post #677363 5th Nov 2023 9:06pm
Defender Fun
Thanks, I’ll try reading the values on my Hawkeye.
What do you mean by “injector has “hosed” and caused a piston skirt to pick up”?
So the injector blocked? Burnt tip?
Sorry for my ignorance, something which would lead to your above being possibly correct is the initial gusto code I got but foolishly cleared without making a note of the code was misfire cylinder 2. But even though I’ve had the car running that fault code hasn’t returned.
Post #677375 5th Nov 2023 10:23pm
dingg1
Look at pulse injector timings on iid tool, anything looking miles out from the others may give you a clue of a dodgy injector , if all similar timing chain jumped a tooth imo.
Post #677378 5th Nov 2023 11:23pm
Before you drop the oil, take the oil filter out and cut it open.
Im sorry to say my wife's 4.4 didn't sound as loud as yours and the oil filter was showing swarf so we have taken the decision to swap the motor out and send this one out for analysis...
So again, remove and inspect the oil filter before you bother dropping the oil...
And finally, if you suspect the injectors? They are simple to unplug. Unplug one at a time and see if the noise disappears? Mine didn't but its worth a try... You'll need a diagnostic tool to reset the MIL light as it won't want to start between unplugging and restarting... Thumbs Up
Post #677389 6th Nov 2023 12:50am
Page 2 of 3 <123>
