![]() | Home > Technical (L322) > l 322 air suspension |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 106 ![]() ![]() ![]() |
i'm having a very similar issue with mine and to answer your question from my investigations your assumptions are correct but i understood the supply was 5 volts not 12.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
"and they stay up over 2 days no problem"
rover75lover Member Since: 02 Aug 2021 Location: wales Posts: 13 ![]() ![]() ![]() |
many thanks for the reply ,it stays on high if and only if i use the rsw softeare to "depressurise " ,the backs lower and the front rise . I then stop the software and it will sit on high no problem. There are no fault codes logged but the high led remains on even if i depressurise it all around .
I think the 6 pins are if you have xenon headlights and the headlight ecu uses the other pins . If the ecu headlight is faulty the air suspension wont work . Thats what one educated l 322 professor told me so its not from peRsonal expeRience . If i EVER crack this walnut ill be back on straight away . Ive done loads on it new compressor new rear height sensors ,overhauled resealed the valve block ,swapped the ecu from my good l 322 and this one still performs the same and my "good suspension" l 322 works fine with my bad suspension l 322 ecu installed . I dont get any faults recorded with the rsw code reader so im beginning to scrape the barrel Ive checked the ecu to valve wiring ,all good . Really scrapping the barrel now |
Typical... just to make it more complicated they have to bring headlights into the mix |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 579 ![]() ![]() ![]() |
Sounds a bit like we are both in the same boat ……I’ve got suspension ecu issues as well (won’t calibrate) and suspension dropping |
Has the arm been flipped the wrong way round? the six-pin sensors can be used in place of the three pin ones, they're two separate units in one housing. |
when it left the MOT place it was flipped unbeknown to me however when it was put right the front pumped up beyond off road and burst both front bags |
hi
that's the one (although a bit tight for space if i remember when i looked at mine) |
