Home > Technical (L322) > 4,4 Tdv8 Cylinder compression test?
EstRR
Hello,
I own a Range Rover 322 4.4 tdv8.
I measured the compression of the cylinders (dry, 10 sec) and got a result of 330-350 psi with a warm engine .
Does anyone know how much this should be or have you measured it on your vehicle?
Post #677382 5th Nov 2023 11:59pm
dhallworth
On an older car that’s done a few miles I’d be more concerned that they were all similar rather than comparing them to the factory original specs.
I think there’s a factory workshop manual in the Wiki on here, you’ll likely find the specs in there.
Post #677384 6th Nov 2023 12:28am
garyRR
What matters with compression is that they're all within tolerance of each other, not what specification said 100,000 miles ago. 2015 Range Rover Autobiography 4.4 SDV8
Post #677450 6th Nov 2023 10:46pm
Phoenix
To a point, yes - there needs to be a baseline for things to 'work' but the high to low isn't bad. What matters is the relative compression and cylinder contribution. It's also not good to have the highest contributor next to the lowest contributor in the firing order. ~300psi is pretty much the low end of diesel compression limits at 16.1:1 and 60psi is generally the acceptable maximum high to low range variance.
So what is the problem that led to the question?
Post #677452 6th Nov 2023 11:09pm
EstRR
The problem lies in the crankcase ventilation and pressure.
The engine has been overhauled, but as is known, original parts for the lower part of the engine are not sold.
New pistons with rings have been installed, there is a question about whether they are tight enough.
Post #677586 9th Nov 2023 7:26am
Phoenix
In that case a cylinder leakage test would be most appropriate, the compression figures are not a good way to determine the rate of leakage as they rely upon movement.
Post #677587 9th Nov 2023 8:15am
