![]() | Home > Technical (L405) > Rear Diff Failure |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 |
My Diff is being replaced as I write, it may not be the same as yours as its a AB which has the clutch pack inside, mine is under JLR warranty.
| Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 200
The rear diff on my 2016 Vogue failed (noisy and leaking oil from the front pinion seal) earlier this year after only 41k miles. Replaced the whole unit under warranty. I think it is a relatively common issue. |
