![]() | Home > Technical (L322) > Strange oil leak 2011 4.4 tdv8 |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3402
The oil pump is below that and they can develop leaks. 2012 TDV8 Vogue (L322) |
| Mariusses Member Since: 09 Nov 2020 Location: Berkshire Posts: 20
Thanks JayGee. I did try to have a look under all those hoses and cables but couldn't spot anything.
It's driven by the aux belt so is well hidden. I'm not saying it 'IS' the oil pump but it's a good possibility. Download the workshop manual from the bottom part of the WIKI section
Thanks.
| TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 439
My throttle body to intake manifold gasket was leaking and blowing backward, similar to how yours looks. 3€ and 15 mins to change, did this last week 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
| LRworkhorse Member Since: 24 May 2024 Location: Hamble Posts: 5
Did you find out what was causing it ? |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777
I suspect a split connecting tube or split seam in the donut.
As in the split in the rubber hose connecting plenum and intake manifold? |
Yes. |
| All times are GMT |
