Home > Maintenance & Mods (L322) > 019 AGM not enough power
Tomc
Northern Ireland 2010 Range Rover Vogue SE TDV8 Barolo Black
Good evening all,
Looking for advice please. I have a 3.6 Tdv8 2010, I have changed the battery to 019 AGM about a year ago it will always start the car ok but it just doesn't give enough power to run my fbh. In fact my fbh has never been able to run in timed heat mode. I have read that some people change the battery to a 020 type. Has anyone had similar issue and the 020 has helped.
Post #678170 17th Nov 2023 10:21pm
Phoenix
It might not be the battery, I've modified several L322's L319's & L320's due to FBH not firing because of volt drop in the circuit, it's pretty simple, run a new fused supply from the +ve terminal of the battery to the power connector on the FBH. 2mm wire & a 15A fuse is ideal.
Post #678171 17th Nov 2023 10:28pm
Tomc
Hi phoenix, thank you for your reply. I will try this ASAP. Have you any details on the power cable and its location on the burner please.
Tom
Post #678175 17th Nov 2023 10:51pm
Phoenix
It should be self-explanatory when you see it, there is a 2-pin connector with heavy wires and a couple of connectors with much smaller wires, one goes to the coolant pump, the other is the control wires - I think a 6 or 8 pin connector with three or four smaller wires.
The red/yellow wire is the one you want to connect to the battery - ignore the above wire & fuse sizes, they're for L319/320 - you need 3mm & a 20A fuse for a L322, 2mm has a high enough rating (25A) but 3mm (33A) will reduce any volt drop, Also make sure the fuse holder is sufficiently rated.
Post #678178 17th Nov 2023 11:08pm
Tomc
Excellent, thank you . Look forward to sorting it soon. T
Post #678180 17th Nov 2023 11:24pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
What length of 3mm wire do you need please for this mod?
Post #678189 18th Nov 2023 12:10am
Phoenix
Sorry, I never measured it - I just used it off the spool. A metre would be more than enough, I used to replace the receptacle in the housing to reduce the number of connections but if you want to joint it to the existing then I'd recommend using a crimp connector with adhesive lined heatshrink covering not soldering.
Post #678201 18th Nov 2023 8:13am
