![]() | Home > Maintenance & Mods (L322) > Altox Fbh timer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35735 ![]() ![]() |
look here,
RobErica Member Since: 16 Nov 2023 Location: Loosbroek Posts: 38 ![]() ![]() |
Thanks Stan,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
I have one fitted.
Bodsy i know from D3 😄 I could ask him there.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
I successfully created a FBH remote triggered by the phone by linking a 4G gate opener and timed relay together. And to save on battery drain, I linked the whole circuit to a thermistor, so it is only on standby below the temperature I set, the rest of the time the circuit is switched off. 2015 Range Rover Autobiography 4.4 SDV8 |
Well, at it again. Fbh works as it should, i can program it and turn it on manualy. But still, no luck with the altox timer. I get code w9. I found a topic regarding a bmw with the same problem, and they said the car goes to sleep, and the processor cant react. I connected my altox to the telestart module. My idea was that the altox would wake up the telestart module, which then would wake up the heater. Guess i am wrong.
Final update.
