![]() | Home > Technical (L322) > 6HP26 Gearbox Help |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
RRPhil is your man
Miky275 Member Since: 14 Jan 2020 Location: Birmingham Posts: 15 ![]() ![]() ![]() |
Yes i have seen Phil is tthe guru when it comes to Gearbox issues.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
Hmmm. You have the uprated transmission with the 4-planet front epicyclic and the 5A/5B/5C/7D/7E clutch plate combination, so you have the 1068 271 120 input shaft.
Hi Phil,
Thanks. I'd be interested to see that.
I believe that JPAT (https://www.jpat.co.uk), Automatic Choice (https://www.automaticchoice.com) and Sussex Autos (https://www.sussexautos.com) are all official Sonnax stockists here in the UK. Phil |
I’ve just had a quick look on the Automatic Choice website and, sure enough, it shows a choice of 3 bushes – 26, 28.1 & 30mm.
Hi Phil,
Unfortunately, Automatic Choice don’t identify the three input shaft options by ZF part number, but I can tell by their list of fit codes that:
Hi Phil,
Oh dear. This must have sounded like such a straight-forward question when you first asked… 😊
Hi Phil,
Well Up date time. To day took on the dreaded task of pulling the gearbox. Took me an my brother 8 hours from start to finish. You was correct in you estimation Phil it was the 30mm bushing. The old bush has almost 0.7mm wear compared to the new one. Also changed all the solenoids along with seals. Will reset the adaptations tomorrow and do the relearn process. But got it to 5th gear and it held there no random shifting or throwing limp mode. So once the adaptations.have been reset tomorrow fingers crossed it's all good. As even though had a 2 post ramp and a fork lift it was a ba@#ard of a job to do 🤣🤣🤣🤣
Yes, congratulations on the rebuild & installation. |
