![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 213 ![]() ![]() ![]() |
thanks need to take a look at mine thanks |
Lionelfcp Member Since: 26 Nov 2023 Location: Paris Posts: 2 ![]() ![]() ![]() |
Hi !
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
The kits are currently on back order.
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69 ![]() ![]() ![]() |
Peltier on ebay: https://www.ebay.de/itm/114223609466?mkcid...media=COPY 2011 Vogue SE 4.4 TDV8 |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
Hi all
Thanks Gary, Ill try that this weekend. If its gone I think Ill try those ones on aliexpress. 150 sterling per side will cost me around €450 incl customs from the UK.
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 ![]() ![]() ![]() |
That Aliexpress seller is in the Russian Federation so delivery to UK is banned, might be same in EU. I might try to find that stuff from another source. 2011c Vogue SE 4.4 Oil Burner 1991 Hilux 2.4d MkIII. Sadly goone due to space and time. 2008 Skoda Octavia Scout 2000 TVR Tuscan 4.0 Loads of crap. Gone Last edited by mcspreader on 12th Dec 2023 6:48pm. Edited 2 times in total |
Another source, this time in the UK but the pricing is rather ambitious. Unless, of course, you can take advantage of the free fitting in which case not too shabby at all.
Fouind this in the workshop manual if it helps anyone. (not much)
Mac35 Member Since: 26 Dec 2023 Location: Angus Posts: 13 ![]() ![]() |
Very informative thread. It’s given me plenty of pointers. I have an L494 Autobiography and realised not long after purchasing it that neither the heated or cooled function works on the driver seat. The passenger side heats and cools as it should. After reading this thread I stripped the back off the driver seat and checked the fan unit. I took it out and checked the resistance of the temperature sensor and Peltier cell. The temperature sensor was about 3 ohms and the Peltier cell was open line. I’m not sure if it can be open line or not? The fact neither heat or cooling work could it be the control module that’s the issue? |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 668 ![]() ![]() ![]() |
Hi,
Awesome, cheers for that Andy. Was it just the back unit that was an issue for you? Neither of the fan units work in my diver seat. I did read on another forum it’s very rare that both go. |
Hi,
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
You looking for these?
