Home > Technical (L405) > TDV8 L405 Engine overhaul
Radek
Czech Republic 2017 Range Rover SVAutobiography SDV8 Mariana Black
Hello
I have such a problem with my RR L405 TDV8.
My car started consuming oil, at first I thought it was just the turbo, it has 160,000 km, but in the end it turned out that the problem would be bigger. When I disassembled the engine, it turned out that the cylinders were out of alignment by 0.2 mm, so I started to do an overhaul with cylinder grinding. The crankshaft was fine and the bearings, I noticed it early. I ordered bigger pistons and now the problem is that I don't know the ttorques for the crankshaft and piston bolts. That's why I would like to contact you here if anyone knows them. I only have torques from the 306DT but I don't know if they could be used for my engine. I don't want to buy a second engine because this one is not to be thrown away. Torque figures are nowhere to be found, not even in Autodata, but I know these engines are being repaired.
Thanks to everyone who can give me advice.
Post #678798 26th Nov 2023 9:33pm
welcome to the forum..
the info you require could possibly be in the workshop manual ...download link in the wiki... ... - .- -.
Post #678799 26th Nov 2023 9:41pm
Radek
No nothing info in the wiki i check it.
Post #678801 26th Nov 2023 9:46pm
Radek
I found it, it was difficult, but I got it, whoever wants it, I'll tell him. Mr. Green
bether i give you for free Whistle
here in gallery buton..
Post #679343 3rd Dec 2023 2:31pm
Kot
I looked through many workshop manuals but never found these torques so well done. Where did you find them in the end?
Keep updating the thread with your progress many on here will be interested in your project Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #679347 3rd Dec 2023 5:18pm
nice find,
Post #679349 3rd Dec 2023 5:29pm
