Home > Maintenance & Mods (L322) > Re Lacquer Air Intake Advice Please
This is what happens after nearly ten years service
I plan to do this myself. Am guessing the intake is plastic,coloured the "right" grey, with a couple of coats of clear lacquer on top. Intend to sand all the lacquer off with fine grade wet and dry, then respray with clear lacquer again.
Door handles have blown too, but tempted to fit the black covers? .
Post #67886 9th Jun 2011 5:01pm
How much is a new one?
Post #67887 9th Jun 2011 5:07pm
Don't know - but that's no fun Wink
See that PowerfulUK do a brushed S/S cover for £120 ? .
Post #67892 9th Jun 2011 5:22pm
daveo
HI i have done my one,they are painted and as standard they dont have clear coat on them..it must of been painted. i used paint from halfords, paint code is on here somewhere, its not hard to get of but while you are there whip off the windscreen scuttle and give it a coat of saturn black, makes a big difference and again while you have the wipers of do them and the plastic covers as well. V8 facelift Range Rover Autobiography 22" wheels.
Post #67916 9th Jun 2011 7:16pm
ric355
I happened to be pricing a new one up today for my car as it has a similar state although not quite as bad. £147 + VAT.
I think you'll need to repaint before lacquer. Getting just enough lacquer off so that it doesn't still show will be tough.
Post #67917 9th Jun 2011 7:17pm
Hmmm... so how to get those wiper adjuster thingies off, (feel another ACME tool coming on!) and do they have to be replaced as it says in RAVE?
Post #68018 10th Jun 2011 11:33am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Low profile ball joint separator or a puller. I used a 2 legged bearing puller.
I definitely didn't replace them- they came off nice and cleanly. Just wire brushed the galvNic corrosion off, greased and re-fitted. Can be a good opportunity to ensure your wipers park correctly. If they already do, just mark the boss and spindle with a permanent marker.
Piece of p155
Good luck!
Post #68101 10th Jun 2011 6:00pm
OK - windscreen guys pulled them off before I could dig out my ball joint separator and have a go!
Anyway this is about the air intake cover.
Removal is one of those keep tugging until all the plastic clips release and hopefully don't break! I pushed up the front one with a pair of pliers, but had to just pull the rear ones up.
Take care when removing the connectors fixed to the windscreen washers the plastic is a bit fragile.
WORD OF WARNING:you can (it seems) only fit the windscreen washers into place with the air intake cover off the car, otherwise the little spouts that take the rubber tube foul the bonnet.
Used a slightly worn piece of P60 aluminium grit to attack the loose and peeling paint, then 600 wet and dry, then 1200 wet and dry to finish before painting and after each coat.
Other than that removal and replacement is straight-forward. Here are pics of the transformation:
Sanded and ready to paint
Primer
First coat
Second coat
Finished product refitted - alongside the before
Worth the effort, a bit of time and a few quid for a can of paint.
Now the door handles beckon! .
Post #68109 10th Jun 2011 7:01pm
a big difference joe.. Thumbs Up
i'm thinking of doing mine satin black..[and the door handles]
Post #68111 10th Jun 2011 7:03pm
Very good Joe , but me being a lazy sod got chipsaway to do it Embarassed
Post #68112 10th Jun 2011 7:05pm
daveo
nice one joe, looks brill.did you do the scuttle..i have the tool to take them off just for reference ..when done it makes a big difference, its nice when you do it your self Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #68128 10th Jun 2011 8:52pm
Yep, nice to do it yourself, as much about having the time and the inclination - as for the skill I'm not a great bodywork person, but if I can't do a small piece of plastic..... Wink
Scuttle just got the "Black Chrome" treatment, no Satin Black in the cupboard today.
Oh, it wasn't lacquer that was lifting it was paint, as Daveo suggested. .
Post #68138 10th Jun 2011 10:04pm
mzplcg
Yup, massive improvement and time well spent Joe.. I had the bodyshop paint mine the same colour as the car (Stornoway) along with the side vents and grille. 80 quid all in.
You might like to think on a 60 grand car that LR could stretch to some plastics which were not quite as cheap. Whistle
Dom.
Post #68162 11th Jun 2011 8:07am
Looks good Joe. What color did you use?
Post #68169 11th Jun 2011 10:23am
Wiggins
2011 Range Rover Autobiography 4.4 V8 Santorini Black
Just done mine, door handles, side vents & small strip above the rear reg in Java black & makes a hell of a difference and a good freshen up
Post #68329 12th Jun 2011 9:39pm
