Home > Technical (L322) > Diesel pouring out! |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 |
It sounds like your fuel tank is not venting, the hose is either blocked or wedged against something, limiting air pressure. Worst case is a split high on the fuel tank or the vent hose itself.
5th Dec 2023 12:28am |
Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 38 |
Thanks for the info Laurie, do you have any idea how accessible the vent pipe is from underneath the car? I hope to get a look once the temperature rises a good bit above 0 degrees! I just hope that l don't have to remove the tank! |
5th Dec 2023 9:49am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
If the rear wheel was off, and the splash shield carfully undone, and removed, you will see the filler tube which has connections to the filler nozzle receiver… that has clips, and might be the source. Wet pipe will tell you what you need to know. |
5th Dec 2023 5:53pm |
Cheers Johnboy, will report back once I've had a look!
5th Dec 2023 6:14pm |
