Home > Maintenance & Mods (L322) > Battery charging via towing port question
Page 3 of 3 <123
FullfatSteve
Thanks Danb_220_2019, appreciate the advice.
They do look like they are fit for the bin.
How easy was it to swap yours out for the 13pin one? Was it follow the old cable to the rear fuse box, unplug existing cables and replace the new wires in the same place and feed cable back to the socket?
second thoughts... I think I just need to replace the existing 12s sockets that are in situ, as I have now purchased the 12s to ctek connector, so that would of been money thrown away, as doubt I can send that back now. So really need to get these old 12s ones working...but likely they are shot and need replacing, like you say.
Thanks again... 2009 Facelift Range Rover Vogue SE 3.6 TDV8
Previous cars :
2018 Range Rover Velar D300 V6
Post #678621 24th Nov 2023 11:18am
DrRob
Same here. I binned the old plugs and fitted a brand new genuine 13pin one for the sole purpose of charging via an adaptor and ctek.
Easy to fit. The tricky bit is getting the integrated grommet to seal properly through the bodywork. Plenty of silicone grease to lube it up Laughing
It looks neater for sure Thumbs Up
Distance selling regs = send your adaptor back and get a 13pin one and fit new 13pin cable etc. Easy job to do. I'll do it for you for a bottle of Rioja Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #678623 24th Nov 2023 11:47am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Thanks again...
Dead easy. I bought a 13pin 'dual entry' socket which is intended to allow conversion from 12N/S to 13pin and allows both the cables to be entered into the socket via a grommet with two cable entries. Just a case of matching the original cable assignments to the new socket. Easiest done by removing the entire sub-loom from where it plugs into the vehicle loom so it can be worked on at the bench. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #678855 27th Nov 2023 5:15pm
KF
Finland 2007 Range Rover Vogue TDV8 Stornoway Grey
Did this mod today, just a standard 13-pin plug and a charger, couldn´t be any easier.
 -07 Stornoway Gray TDV8
Post #678860 27th Nov 2023 6:58pm
pcourtney
I need to do the same thing, but I have the older 7 pin plug aka 12N
Looks like I will have to buy one from Screwfix and also get the CTEK Comfort from Halfords
https://www.screwfix.com/p/maypole-mp021-7...-12v/80465
https://www.halfords.com/motoring/battery-...66622.html
Shall I use the fog light Blue pin to trickle charge the battery using my CTEK
Post #678865 27th Nov 2023 8:09pm
RangeRov
Sweden
A curious question, would it be possible to do any modd so you can charge the battery at EV charger stations via the towing port?
Post #679302 2nd Dec 2023 3:24pm
mjdronfield
No idea, but if I were a betting man, I’d say no, as the battery technology is completely different and so charging rate, voltages etc will be massively different.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #679303 2nd Dec 2023 3:41pm
pcourtney
No, the EV stations use 400 volts ( not 12V ) , some of the newest ones for Porsche Taycan's etc use 800 volts !
Post #679375 3rd Dec 2023 9:38pm
Gremlin500
400V/800V into a 12V battery, wow that would be super fast charging!⚡️ Shocked 💥 V6 Vogue - “Less is More” - less to go wrong!
Post #679376 3rd Dec 2023 9:51pm
Phoenix
Post #679383 3rd Dec 2023 10:13pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
[quote="pcourtney"]I need to do the same thing, but I have the older 7 pin plug aka 12N
Paul :
I don't think you can use the Blue (Fog light) pin unless you rewire it inside the boot to connect to a battery permanently live connection rather than fog lights - which as well as being normally switched off, would also connect through either the BCU or lighting ECU.
PS If you've got the minor electrical skills , you could use a 2 way switch to change the feed to the 12N socket from the fog light to the battery live .
You've then got the option for charging when you want or conventional tow bar electrics for towing when you want. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #679410 4th Dec 2023 12:43pm
Page 3 of 3 <123
