![]() | Home > Maintenance & Mods (L405) > Front end clunk I’m lost |
sconnell80 Member Since: 17 Nov 2023 Location: New York Posts: 46 ![]() ![]() ![]() |
I did just check and the fluid is just below the minimum fill line so I’ll have to pick some up I guess |
Here in the states it doesn’t list much for being equivalent to the box store stuff. I did see a local store has Pentosin chf 202 which is saying it is equivalent to the LR stc50519 but I’d hate to put something in there that isn’t gonna work and cause major damage. I know Land Rover used to use this fluid in the ace but have switched after a certain year. |
Well that does help as the CHF 202 is listed there and when I look up the Ford specs it lists the same thing. The only thing I can get around here without ordering is the CHF 202 |
On the way home when going straight I rocked the steering wheel left and right and get the clunk both sides up front so now time to recheck everything and see if I can bleed the ACE |
Well turns out the brand new sway bar links were junk that I put on. Didn’t even last a week. Brand new sway bar links and now it’s nice and quiet. |
