![]() | Home > Technical (L322) > 4.4TDV8 “SUICIDE” Hesitation, Good INDY Specialist Req |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3321 ![]() ![]() ![]() |
Try cleaning the MAP sensor? 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
All torque converter and turbo set ups will have a tad delay whilst everything engages and gets you going.
Benjerbustmills Member Since: 24 Mar 2021 Location: Thornbury , Bristol Posts: 31 ![]() ![]() ![]() |
Thanks for your comments .
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 780 ![]() ![]() |
Are you sure it’s not just the gearbox pulling away in 2nd then they pause is when it drops to 1st?
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
Mine does the same Si and it's very annoying especially when I'm trying to get in a 'gap' in the traffic flow. I try and put a few gentle revs on just before the launch into the gap which seems to help. When I've got time I'm taking mine to a local ZF gearbox specialist who is going to map what the torque convertor is doing. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
as you mentioned that the fault won't happen when in command shift mode.... maybe a quick free 'prove' might be to reset the gearbox adaptations. so it learns a new driving style. -in normal mode, and see if it repeats... i can't remember the method, but it must be on here somewhere. some cars you do a sequence of pedals and buttons to reset it, and it takes about 200 miles to relearn. -a free go at a problem, that might get flagged at your chosen indy, and only you can 'drive it out' |
The MAP sensor is on the top of the engine intake - the MAF sensors on the airboxes never need cleaning. 30-40mins for a run to clear the DPF or activate a regeneration is not long enough IME. Mine has instant and smooth power with no hesitation and it's nudging 170k miles now and still has the 'eco crap' fitted. As yours is a very low miler it would also offer the possibility that it's just done very small trips all it's life which will not have been kind to it. 2012 TDV8 Vogue (L322) |
Resetting the gearbox adaptations involves a diaghnostic tool like the GAPIID but is not recommeneded unless you have changed internal components. You can reset the throttle by holding down the accelerator to the max limit and then powering up the car for 30 seconds then powering down and releasing the pedal. This can smooth out gear changes IME. 2012 TDV8 Vogue (L322) |
Beware of ressetting things, you could unleash a whole wold of problems. This sounds like it's just a characteristic that you can probably drive around with S or manual mode. |
You can't unleash any problems doing a throttle reset. It's helped on my L322 and my previous Audi ( which had a ZF box) 2012 TDV8 Vogue (L322) |
I reset my adaptations and it made things a whole lot worse for nigh on a thousand miles. Don't do it! |
Was that the throttle or gearbox adaptations? 2012 TDV8 Vogue (L322) |
Gearbox. |
Did you do the adaptation drive procedure afterwards? 2012 TDV8 Vogue (L322) |
