![]() | Home > Technical (L322) > Late L322 Ford Era Fan Noise From Behind Glovebox 2012 |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 701 ![]() ![]() ![]() |
Hi,
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
One possibility is that the noise could be coming from the climate control panel, not sure about your year car, but some control panels have a small fan built into the panel, maybe a possibility ? |
Hi,
If it's narrowed down to the climate control panel, removal of the panels is easy, but do it gently as there is an ECU built into the panel that controls all climate functions.
OK, thanks, I'll see if I can narrow it down further.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
There's also a fan in the audio head unit.
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 46 ![]() ![]() ![]() |
I might know what you´re after, although have no answer, unfortunately.
Hi,
Hi,
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 955 ![]() ![]() |
Good to hear you’ve located the source of the hum |
Yes sorry, to clarify its the FBH water circulation pump on the FBH itself.
