![]() | Home > Maintenance & Mods (L322) > suspension issue |
https://www.gap-diagnostic.com/wordpress/w...lV4.00.pdf
If there was an issue with the valve block, then I'd expect DTC's to be set - have you got the arm on the height sensor you replaced the correct way round? and for the correct side?
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 584 ![]() ![]() ![]() |
the height sensor was replaced last December and that cured the red flashing marker i was getting on that corner so don't think the height sensor is at fault ...hoping to jack the car up tomorrow and check the valve block -air lines/connectors and wiring (weather depending ).dtc ? do you error codes ? if so i get suspension fault on dash that's it outside of gap tool |
DTC = Diagnostic Trouble Code = error code
when i get a chance ill pop them in |
right on going suspension problems..... one issue now sorted can now change ride heights, how ever over night the car drops on all 4 corners .put to off road height removed eas relay in boot in the morning the front had dropped rear still up |
Right replaced front valve block seals(again) and also fitted new height sensor (genuine)front now stays up π
