![]() | Home > Maintenance & Mods (L405) > Spongy brakes |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1883
@Phoenix:
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575
100% agree with Phoenix - pressure bleed + pump pedal. Had issues with bleeding a Vauxhall van the other day. Used the vacuum bleeder after changing a caliper - no good. Air had got well into it, even though hoses were clamped off - but left a couple of days whilst caliper was exchanged. Got out the pressure bleeder running at 30psi, still couldn't get a decent pedal, it was clear there was air somewhere in there! Pressure bleeder + pumping of pedal with bleed nipple removed (carefully watch reservoir / pressure bleeder fluid levels) made for a rock hard brake pedal! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
| Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 204
Thanks for the info lads. I'll have another go at it tomorrow, weather permitting and report back. I had thought of pushing the pistons back into the calipers to get rid of an extra hiding place and even taking the calipers off to position the bleed nipple right at the top like you sometimes have to do with motorbikes but as has been stated I think the air is hiding in the roller coaster.
'Happiness is a firm pedal'. Well more firm anyway. Bled the brakes using the fast pump and pressure bleeder method. The pedal is much better now, rock solid with very little play with the engine off. Start the engine and it sinks a bit, which is normal but then it still feels a bit spongy, more than my other cars. My good Lady says it's me being a faff and she's fed up pumping brakes so I'll see how it goes.
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
Had quite a few of these play up after new hoses / pipes, try bleeding it with he engine running, it does make a difference |
That is the plan. I'm still not 100% happy with them but there's only so many times you can bleed them. On the run the brakes are fine ......just still a bit spongy. Engine running and 28 pumps as per the manual at the next opportunity |
Bled the brakes AGAIN with the engine running as per the manual. Still the pedal is rock solid with the engine off but it sinks to about 50% when I start the engine. I'm beginning to wonder if this is how they should be, the brakes are brilliant on the road and the first 50% gives very progressive braking so even in the soft zone it. Maybe I'm just used to older braking systems.
