Home > Maintenance & Mods (L405) > Failure driver seat massage and function
Page 2 of 3 <123>
Hoyboy
We had this happen with our 1 year old Autobiography. The part was also on back order at the time as well. I called out Land Rover Assist and asked if we could have a courtesy car as it was too uncomfortable to drive which they agreed to give us. Suddenly the part was no longer on back order and the car was fixed within a couple of days. Funny that
Post #671303 16th Aug 2023 4:46pm
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
I had the same problem on my FFRR. The dealer did a software update on the vehicle two weeks ago and so far it seems to have cured it. 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #674871 4th Oct 2023 12:50pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I think I have this problem for a second time. Yesterday the massage again starts then just stops. The dashboard and button both say it is still going but it’s not.
I might try the wiggle the wires… SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #680439 16th Dec 2023 6:54am
hughjayteens
2005 Range Rover Vogue Td6 Java Black
Post #681641 1st Jan 2024 6:06pm
luxmoggy
Was fixed under the extended warranty SDV8 AB MY 2020
Post #687577 8th Mar 2024 8:55pm
Chip41
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
Does anyone know what exactly the fix is for this (if you don't have the extended warranty)?
Is there a specific part which needs replacing in these circumstances?
Post #706460 9th Dec 2024 12:00pm
luxmoggy
I am not the best person to answer. Mine has broken again. They are thinking something else is causing the issue. SDV8 AB MY 2020
Post #706565 10th Dec 2024 10:32pm
luxmoggy
I will look up the part number that they replaced.
LR101122 LUMBAR SUPP BACKREST SEAT SDV8 AB MY 2020
Post #706566 10th Dec 2024 10:32pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
My new to me SV has this problem with the middle back bag fully inflated and no massage.
So what is the fix?
Post #719878 16th Jun 2025 4:32pm
zenman63
Just adding to this post.
As above it’s the seat back frame, one unit with the pump and both solenoid valves and all the lines and air bags.
Post #721213 13th Jul 2025 9:59am
rk7
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Carpathian Grey
Mine does the same, where it will start and then stop after 5 seconds or so. However I can use the upper body massage but only once and once stopped the whole thing needs a reset by locking and unlocking the car. Once reset I can use the massage and other lumbar function. Massage (upper) only works once. Any other massage just stops after 5 seconds.
I tried switching the seat module but it did not make a difference and have the same issue still.
After 5 seconds or so when it does stop it stops in the middle part of the seat. And gets stuck I even removed some of the pipes from the valve body to deflate the stuck bladder and test but even if it’s not inflating it has the same behaviour of stopping after 5 seconds.
Could it be a software issue? Replacing the whole massage frame doesn’t make sense to me. L405 2021 Range Rover Vogue Autobiography P400e
L405 2016 Range Rover Vogue TDV6 - Sold
L405 2019 Range Rover Vogue P400e - Sold
L320 2013 Range Rover Sport SDV6 - Sold
Post #724412 12th Sep 2025 5:09pm
zenman63
The frame comes complete but I do have from mine both modules and the pump.
Bags will be fine.
However one module is faulty and no idea which one.
No software will fix it.
Post #724423 12th Sep 2025 7:59pm
rk7
@zenman did you replace the frames yourself or did you have a garage do this?
Just wondering how difficult is this and if it’s worth the headache. I mean I have a workaround for the upper body massage so wondering if I should bother with the rest.
Also where exactly is the module within the frame? I thought the modules were under the seats. Next to the seat heater module. L405 2021 Range Rover Vogue Autobiography P400e
Post #724426 12th Sep 2025 8:43pm
zenman63
I did it myself, it’s a job, 5 hours with two and around £700 in parts.
Module you can see with the seat back off but no chance getting them out.
Pump is inside the seat foam and is also impossible to get at without the seat cover off.
Post #724454 13th Sep 2025 10:25am
rk7
Oh wow that's a lot of time.
Thank you for the details.
I will probably leave it as it is for now and revisit it later. Not the end to the world right now with most other functions still working including the upper body massage.
If you've got more pictures please feel free to share as I am sure that will help a bunch of folks knowing where the little wires, tabs..etc.. are.
Thank you once again. L405 2021 Range Rover Vogue Autobiography P400e
Post #724455 13th Sep 2025 10:36am
Page 2 of 3 <123>
