|  | Home > Technical (L322) > Battery drain test procedure |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    |
 It is   Guessing the age of your car from your dash image in your other topic, try disconnecting the SatNav DVD in the boot. Take it out and dismantle it to check the PCB, clean with contact cleaner / isopropyl and a toothbrush . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember   Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 | ||
|  17th Dec 2023 5:35pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | You could try one of these, the advantage being you can check for current drain on individual fused circuits. EBay item number eBay Item No. 400433639239.
|  17th Dec 2023 5:44pm |
| camcc Member Since: 01 Oct 2023 Location: Godalming, Surrey Posts: 38    |
 It's a 2005 4.4 AJV8. Thanks, will give that a go. | ||
|  17th Dec 2023 5:52pm |
 Thanks for the suggestion. You mean mount the amp clamp so I can read it from inside the car? | ||
|  17th Dec 2023 5:58pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | ... | ||
|  17th Dec 2023 6:08pm |
 Outside the car.   | ||
|  17th Dec 2023 6:18pm |
 Sorry for the dumb follow-up questions...but... connect the red lead to the battery clamp - to the positive battery terminal? disconnect the end of the battery ground lead from the body - this is the brown cable the connect to the negative battery terminal? I will need to use a torch tomorrow but I can't see where this is removed from exactly. 2005 L322 4.4 AJV8 | ||
|  17th Dec 2023 6:39pm |
|  17th Dec 2023 7:01pm |
| jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 201      | better solution - use clamp amp meter. | ||
|  17th Dec 2023 7:33pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | Clamp meters are notoriously inaccurate (unless you're spending a few hundred on one) for any measurements over a few minutes as the DC current will cause eddy currents in the metal clamp, in turn creating a small permanent magnet, which causes an increasing 'drift' in the reading, which is why it is specified to use an in-line ammeter in dealer diagnostic routines for measuring quiescent current draw.
|  17th Dec 2023 7:52pm |
 Thanks, this is really helpful. I'll see if I can remove the ground cable from the body tomorrow as I just installed a larger 020 size battery and might not be able to get at it easily! 2005 L322 4.4 AJV8 | ||
|  17th Dec 2023 8:29pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      |
 I do like your approach, but it seems you can only test up 20 amp fuses with those devices, so I suppose the sensible thing to do is not to use them on 30A fuse holders   | ||
|  17th Dec 2023 10:39pm |
|  17th Dec 2023 10:45pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | True enough Phoenix - thx | ||
|  17th Dec 2023 10:46pm |
| Posting Rules
