![]() | Home > Maintenance & Mods (L405) > L405 roof bars ! |
| Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1096
I’ve only ever fitted a ski carrier to my roof bars and never had a problem. The bars lock into the rails with a securing pin and should be rock solid; if they’re not, that means the securing pin hasn’t seated into the hole in the rail. It can be a faff, but once you’ve worked it out it’s a doddle. |
| mkacala Member Since: 22 Nov 2023 Location: Bucks Posts: 31
hi thanks Andy ! i saw the holes in the rails but didn't know they were for a pin ? I'll go back and refit ! many thanks |
| James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303
Drove to the south of France this year with a huge, loaded roof box on. I know what you mean about the cross-bar clamp, I also expected something a bit more obviously secure. I just really took my time to make sure the bars were straight and aligned so that as I tightened the bolt that secures the clamp, it got the best purchase possible on the rail and it was sat into the little groove as well as possible.
There’s a small lug on one side of the clamp for each bar which you have to line up with the hole on the roof rail, same for both sides. If the lug, or pin, (same thing) isn’t aligned then the bar won’t sit securely. You have to make sure the bars are on the slackest tension when fitting as that allows them to move on the rails to align the lug. Once in position, tighten up the bars - they should have a torqued screwdriver like device as part of the kit so you know how far to tighten them.
| ABAB Member Since: 02 Feb 2017 Location: GB Posts: 288
I have used the RR roof bars and a large LR box (Thule made I think) many times without problem. Definitely need to get the lugs from the bars to fit into the notches on the rails. Make sure you’ve got the bolt tightening tool which gives a good visual indication of the 11NM (I think) specified.
gents , thanks for all advice .... didnt get a chance today , but over next day or so will take pic of rail holes and bars and post . |
