Home > Maintenance & Mods (L405) > Rubber for engine cover….
Hi chaps,
Does anyone know if the rubber doughnuts/bungs/washers which hold the plastic engine cover on to the studs on a 4.4sdv8 are available separately?
The rear 2 on mine seem to be missing. The front 2 are there, but there aren’t any on the back 2 points.
Cheers There is nothing that can't be fixed with a hammer😜😜
Post #680646 18th Dec 2023 4:03pm
You can get them from ebay for a Ford Mondeo, they are the exact same ones...
Ford part number 1434444
JLR only sell them with the lid...!!! Pete
Post #680659 18th Dec 2023 4:58pm
Baltic Blue
Could they be the answer to your other post ??
Pretty smelly if they got stuck to a hot exhaust ?
Post #680661 18th Dec 2023 5:08pm
good tip Pete.. Thumbs Up
cheap as chips on ebay,
possibly cheaper from other sellers.. ... - .- -.
Post #680662 18th Dec 2023 5:10pm
Gremlin500
Here you go:
https://www.ebay.co.uk/itm/254853258811?mk...media=COPY
These do fit, -got them on mine! Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #680663 18th Dec 2023 5:11pm
Brill, top tip thanks guys. I’ll get some on order…..👍🏻👍🏻
I couldn’t see them on microcat listed separately so figured LR would want ££ for a new cover. There is nothing that can't be fixed with a hammer😜😜
Post #680672 18th Dec 2023 6:02pm
BB, don’t know, possibly but I’m not sure they have ever been there since I’ve had the car!
I’ve only had the cover off a couple of times and can’t recall if they were present. my bet is they fell out during a service and they just put it back on anyway…… as both of the back ones are absent. I’ve ordered some of the Mondo ones from the Bay and that will fix that!
Will keep an eye There is nothing that can't be fixed with a hammer😜😜
Post #680674 18th Dec 2023 6:09pm
supershuttle
Yes I paid a tenner plus postage for my 4 (only wanted 1) but they look like the same ones (even though mine had a bogus part number LR 030). At least I now have a few spares and the engine cover is fixed properly. Geoff
Post #680678 18th Dec 2023 6:34pm
My rubbers for the cover arrived and I can also confirm that the Mondeo ones with the links above are absolutely spot on and fit like a dream!
Job done!👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #680954 22nd Dec 2023 6:19pm
Thumbs Up Thumbs Up Pete
Post #680958 22nd Dec 2023 6:37pm
Well Censored me…..
I’ve put those rubbers in and it’s had another bonus result.
Ever since I’ve had the car it’s had a strange noise at just over 1000rpm, slight buzzing coming through the steering wheel/resonance. Big Cry
Another member had a similar problem a while back, mine didn’t get any worse or better so after I’d looked really hard for the source, I’ve ignored it for 4 years……. Whistle
Could have fixed it for a couple of rubber bungs!!! It’s gone. Must have been the cover vibrating on the posts without bushes. One to remember if anyone else has similar issues. Check you have all the cover rubbers!! Rolling with laughter There is nothing that can't be fixed with a hammer😜😜
Post #681012 23rd Dec 2023 4:02pm
i should imagine that after a while they would get kinda brittle from the engine heat ..
time to order some new ones .. Thumbs Up ... - .- -.
Post #681013 23rd Dec 2023 4:29pm
Probably Stan, but for how long I’ve had the noise I reckon some lazy tech mis-located them during a service and just bunged the cover on with the 2 front fixings only. It was LT who had that noise similar to mine, just updated that thread. There is nothing that can't be fixed with a hammer😜😜
Post #681037 23rd Dec 2023 7:18pm
Phoenix
Yer, always the tech eh? Yawn
Post #681045 23rd Dec 2023 8:39pm
if a garage normally does your work then probably.....no ones perfect.
mine just had a replacement lower arm fitted because the 'tech' at the dealership damaged the ball gaiter when fitting the recall knuckle arm... ... - .- -.
Post #681060 23rd Dec 2023 10:10pm
