![]() | Home > Technical (L322) > PO700 fault code |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
https://www.mycarspecs.com/obd2/land-rover...il-request
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 112 ![]() ![]() ![]() |
Thanks for that , had oil and filters changed about 25k miles ago , came on first time at startup when stationary , didn't come on whilst driving ?? and having looked through that info it all relates to whilst in use , and no fault codes showing up in transmission ECU |
Rrphil may pipe up with a better reply if he's seen the problem and reason before
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1357 ![]() ![]() ![]() |
Did you manage to resolve this problem? Mines just showed this code along with P2459 and P0195.
CarlM93 Member Since: 23 Oct 2023 Location: North Warwickshire Posts: 9 ![]() ![]() ![]() |
Hi guys, i have the exact same issue after a flat battery.
UPDATE - I took the car on 3 drive cycles and eml light went off on its own |
