![]() | Home > Technical (L322) > Limp Home Mode on potential purchase, what might it be? |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 85 ![]() ![]() ![]() |
what error messages flashed up? If it was a DPF fault it will come up amber DPF Full see handbook or red DPF full see Dealer. and there are different ways of clearing both of those.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Yep, could be anything from a £20 sensor to many thousands of £'s....
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
If you really like the car and are prepared to spend up to £3k to get it sorted, offer him £10k , then walk away if he says no.
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 88 ![]() ![]() ![]() |
Hello everyone, thanks for the quick responses.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Walk away…plenty of much better ones out there come up for sale
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 194 ![]() ![]() ![]() |
If you don’t proceed I am going to be listing mine over Christmas as I can no longer afford to run multiple cars.
What timescale and price are you thinking ?? |
Previous comment was to DrR, cheers for the info though! Last edited by RovingCanary on 24th Dec 2023 10:32am. Edited 1 time in total |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 286 ![]() ![]() |
Here is his thread https://www.fullfatrr.com/forum/topic68656.html Hunt for a L405 is on. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
Being a 4.4 TDV8, it's most likely an intake leak.
Cheers Gary, yes he said it happened upon first purchase and the DPF needed a chemical clean. The reaction to the fault coming up indicated to me it hadn't happened before, otherwise would have had a pre-made excuse. Or maybe I an being naive, but either way the commentary here has been very useful. Intake manifold sounds expensive, unless its just a joint to be remade. Will see if Surrey Jag & RR can do a diagnostic for a reasonable sum, otherwise will leave it and find another. |
Intake leak is different to intake manifold.
If my test drives prove positive then it’s a case of finding the right spec one. Then I’ll sell. Jan or Feb etc I’ll update on the post already linked Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Thanks Gary, that sounds an easier fix if the culprit.
