![]() | Home > Technical (L322) > Windscreen misting up |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
Have you got the aircon on, this dehumidifies....
Herald Member Since: 11 Aug 2016 Location: Surrey Posts: 16 ![]() ![]() ![]() |
AC on all the time, never turn it off. Even with the AC on it is struggling to stay clear, mists up when parked and takes an age to clear when setting off unless I activate the heated front screen. This is a significant departure from normal and having owned the car for nearly 6 years, it’s definitely not right now.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3826 ![]() ![]() ![]() |
The A/C drains under the car and usually leaves a little puddle.
I think it’s the correct way up, the air flows in the direction of the arrow. Interesting thought though thank you, what difference does it make to the water ingress? It looks like it is symmetrical too to bottom so I always assumed the flow was a filtration thing not a water issue. |
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 67 ![]() ![]() ![]() |
It might be worth removing the pollen filter housing and checking the seal to the bulkhead isn’t deformed. |
Water is allowed into the pollen filter housing and the drains are free flowing. Doesn’t seem designed to seal? |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 761 ![]() ![]() |
Is the AC working OK? Does it need serviced? |
I’d be inclined to have a look under your front carpets. |
It gets cold perfectly OK. It doesn’t get warm at all quickly. So I’m presuming that as it gets cold OK, the dehumidifying effect is still working as the two are inextricably linked. |
Done that! Lifted them and all dry. First thing I did. |
