Home > Off Topic > Has anyone bought an in car electric coolbox?
Thinking of getting one for the long trip to Provence and back, handy for keeping some things cold, including drinks etc.
Looked at Halfords and they have a 30% offer on at the moment. Clearly not the type of thing you want to leave plugged into the 12v socket in the boot for a few hours when the engine is off but hoping they can retain their coolness for a few hours and can then be left without too much worry of things getting too warm.
Anyone got any hints tips or recommendations?
Thanks Discovery 4 HSE
1993 90 Tdi
Post #68108 10th Jun 2011 5:59pm
http://www.gooutdoors.co.uk/product-search/text/coolbox
2nd one
Post #68110 10th Jun 2011 6:02pm
Is that a recommendation Mick? Do you have that one yourself?
At least that one comes with a mains adapter, Halfrauds is extra na dTBH< most of Halfords own brand stuff tends to be rubbish. Discovery 4 HSE
1993 90 Tdi
Post #68126 10th Jun 2011 7:41pm
I have just bought one from lidl last week. It has mains and 12v on it. 29L capacity, Was much cheapness! But good quality... £25? I think... Previously..
Post #68129 10th Jun 2011 7:54pm
Fox
I've had two from Halfords. The old one was 8 years ago and we took it around Morocco.
Cost £30. Most of the others had £500+ engles etc... and ours was fine in an air-conditioned car.
As I lost the lead for it I bought one of the new range they do in blue for a trip over Easter to Wales.
Worked fine. Bargain IMO for £35.
Just check the distance from the boot floor to the parcel shelf as the air inlet is on the top, then compare to teh coolbox dimensions If it's too close it'll struggle to get the air into it.
They do make a whirring noise, but if you have the parcel shelf down you won't hear it while driving.
Post #68133 10th Jun 2011 8:41pm
The loud pedal's for drowning out the noise Thumbs Up
Post #68135 10th Jun 2011 8:46pm
Fox,
Thanks for the tip, will look into that. Discovery 4 HSE
1993 90 Tdi
Post #68147 10th Jun 2011 9:37pm
brumster
United Kingdom 2006 Range Rover SE TDV8 Buckingham Blue
Might be worth a look as well, some good reviews:
http://www.amazon.co.uk/Campingaz-Powerbox...amp;sr=1-2
Edit: And another here that looks similar to the one Contraband mentioned but from Aldi:
http://www.aldi.co.uk/uk/html/offers/special_buys3_19198.htm
P
Post #68153 10th Jun 2011 10:17pm
mzplcg
Some are OK Adam but avoid the really cheap ones. I have one of the campingaz ones which is OK. Worked better in my old D3 which had privacy glass. Also avoid ones which are top vented cos they don't always work well under parcel shelves.
What I also found is that it helps to line the base with those freezer blocks and also pre-chill contents in a normal fridge before use. In other words, quite a bit of messing around............which is why I now have a National Luna. Thumbs Up
Still have the trusty 12v coolbox which you're welcome to have. Works etc and never let me down.
Dom
Post #68161 11th Jun 2011 6:37am
Not got one myself Adam , just copied the link to give you a rough idea of price and quality ….. Thumbs Up
Post #68166 11th Jun 2011 8:38am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Had the older model coleman for what seems like 10 years by now.
Here is the modern one, different colour, same thing
http://www.coleman.com/coleman/colemancom/...amp;brand=
Works really well in the car, and outside if you have a power supply or portable battery, and it's lighter than an engel or national luna so you can really just lob it on the back seat and not worry about the leather.
Not as power efficient as a real fridge (like the engel/NL) draws a constant 3-4A regardless, but if you put cold stuff in, it will keep it ice cold
Post #68237 12th Jun 2011 6:19am
allycraven
Not tempted by the OEM offering then? Only £110 Shocked
part no: VUP100140L
Post #68571 14th Jun 2011 6:18pm
Andy
We have one at work. My Team have sole use of a Public Order van and we are a team of 10, so we are out all day on the van. We keep cold drinks and chocolate in ours.
Its mains powered too, so we take it of the van at the end of the shift and plug it in at work. Its a decent size one, but the name of it escapes me. I'll have a look next week. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #68649 15th Jun 2011 10:38am
supershuttle
Got one from Halfords - the smallest. Fits in the rear footwell perfectly, keeps drinks cool perfectly, yes its noisy and no it doesn't have a mains adapter, although I'm not sure why I would need one - I just use it to cool drinks and keep them cool which it does fine. If i want them to go in cool to start with i just use the big white box marked "Bosch" in the kitchen.
I took the Outwell one back as it was also noisy but in a worse way.
Halfords do have a good returns policy - money back if not delighted - so nothing to loose by trying one.
I'm not a particular Halfords fan but I've never had an unresolved problem there, I guess by the comments others have had different experiences. Geoff
Post #70055 26th Jun 2011 8:09pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Dometic RC2200EGP
Not cheap,
cools to around 35 deg c below ambient temp.. cool enough to make ice cubes!
Nice look too. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #70132 27th Jun 2011 3:48pm
