Home > Maintenance & Mods (L405) > Any recommendations for remap
Pablo398
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi, new to the forum as recently purchased a 4.4 sdv8. I’m looking at getting a remap to get rid of the dreaded lag when pulling out of junctions in a hurry. I live in Carmarthenshire wales so wondering if anyone has used anyone in my area. And any feedback from anyone who has already had a remap good or bad. Thanks Paul
Post #682202 8th Jan 2024 10:40pm
GraemeS
Australia
Ensure that the MAP sensor is clean as it gets clogged which then affects performance.
Post #682212 9th Jan 2024 3:36am
Pablo398
Yeh map sensor clean. Had exactly the same issue on my Evoque.
Post #682245 9th Jan 2024 3:18pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Never noticed any lag at all on SDV8. Certainly have on the Evoque however which is mentioned above. 2016 SDV8 AB
Post #682255 9th Jan 2024 4:51pm
Pablo398
Not sure if lag is the correct description. Occasionally when I need to pull out quick in busy traffic there is a delay before throttle response. If I’m driving normal never notice anything.
Post #682257 9th Jan 2024 5:14pm
ABAB
Pablo - I know what you describe on the Evoque (my experience was with a 2012 SD4) where it was almost embarrassing at junctions and roundabouts the extent to which you had your foot down but nothing seemed to happen for a couple of seconds.
I’ve never had anything remotely similar with the FF however. Would be interested to see others’ thoughts before you embark on any replumbing or reprogramming. 2016 SDV8 AB
Post #682261 9th Jan 2024 5:27pm
Pablo398
Yeh that’s it. Thought it would me more common. Searched Google and there seem to be a few people with issues and apparently a remap solves it.
Post #682267 9th Jan 2024 6:08pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
I imagine any remap that “solves” it will just be like one of those pedal box things which just amplify the signal from the accelerator (so 50% throttle becomes 75%, or whatever).
Post #682270 9th Jan 2024 7:40pm
GraemeS
Australia
My 4.4TDV8 L322 has been remapped, primarily to disable EGR but with a little extra power on WOT because the cost was the same. I had done a test with EGR blocked and the improved throttle response was substantial, but overall undrivable due to the PCM closing the EGR butterfly trying to reduce clean air flow and increase EGR flow as soon as the accelerator was backed-off. I wasn't prepared to remove the throttle plate as I have installed a system to close the EGR butterfly for a while when the ignition is switched off to ensure no engine runaway if the primary turbo fails and puts oil into the air intake.
Mine's remap was ex-UK on about a 1 hour turnaround via a local installer.
Post #682276 9th Jan 2024 8:55pm
fisha
The Evoque issue for me was it trying pull away in second for a smooth acceleration initially, you think its too slow so plant the throttle, it then realising you wanted full effort, so it would do a change down ( i.e pause even more) before then launching. Net result , crap take off.
I’ve never felt the sdv8 8 spd be as bad as that, but if i know I want a launch it from a junction I’ll use the paddles to pull it into 1st.
Maybe try that for a bit before committing to a remap. V8 or else ...
Post #682302 10th Jan 2024 12:37am
