Home > Technical (L322) > TDV8 Idling Rough
Trev
2007 Range Rover Vogue SE TDV8 Java Black
TDV8 Idling Rough
Hi guys , I was wondering if anyone may have any idea what's wrong with my car. Going back a few months the EML came on and it was diagnosed as being a faulty EGR Valve. The guy who was doing the work wasn't sure which side it was , so gave both valves a clean out and all was well for a few months. Over the last couple of weeks however I've noticed sometimes it is sounding really rough when idling as if it's only running on one bank of cylinders and the whole car judders. When it is revved up it seems to clear itself. This problem seems to be occuring more regularly and I was wondering if it could be linked to the suspect EGR Vavle? Any advice greatly appreciated.
Post #67470 7th Jun 2011 4:56pm
Could it be a faulty MAF?
Post #67570 7th Jun 2011 10:00pm
Trev
Hi , thanks for getting back to me . I took the car back to the garage yesterday and got it plugged back onto the computer. The only fault that is coming up is the EGR valve.Looks like I will have to get it booked in next week to try to get to the bottom of it. Cheers.
Post #67671 8th Jun 2011 1:49pm
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
TDV8 rough idle is a known issue by Land Rover, it has taken me nearly two years to fix the issue with several visits to dealer. Finally a software fix was developed and should have corrected the problem. Make sure your dealer down loads the update and installs it for you. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #68233 12th Jun 2011 12:54am
Steve L
South Africa 2008 Range Rover Vogue TDV8 Chawton White
TDV8: ROUGH IDLING
I have spoken to my local agents and they are adamant that they have the latest software downloaded and installed on the car. They have also replaced the engine mountings. In my particular case, the rough idle is only when the car is in 'Drive' and I am holding it stationary with the brakes. In 'Park' it idles perfectly smoothly. Any ideas?? Cheers
Post #79686 7th Sep 2011 10:30am
RRD
Belgium 2012 Range Rover Vogue TDV8 Santorini Black
*Kick*
When I google several people seem to have a TDv8 idling rough, but no real answers / solutions are given.
My car idles very roughly + it goes in safe mode every now and then. We read the OBD and it gives faults on rail pressure and fuel pressure...???
Any ideas, before I take it to the dealer. '17 Range Rover 5.0 Supercharged AB (Sold)
'16 Range Rover SDv8 AB (Sold)
'15 Range Rover SDv8 Vogue (Sold)
'13 Range Rover SDv8 Vogue (Sold)
'12 Range Rover TDv8 (Sold)
'10 Range Rover 5.0 Supercharged
'03 BMW E39 M5
'01 BMW E46 M3
Post #253398 8th Apr 2014 9:32pm
adigorn
rough idle under load would indicate injector problem
did they check injector readings
Post #253426 9th Apr 2014 6:38am
adigorn
You kind of answered your question Yourself
would advise to take a look at h/p sensor but its quite difficult to access so
dealer time
Post #253427 9th Apr 2014 6:40am
adigorn
Shocked
a clean out ?
you need to diagnose the fault and replace faulty part
cleaning is not going to fix an EGR in tdv8
Post #253428 9th Apr 2014 6:43am
RRD
yes, we did check injector readings, but ofcourse the car ran fine when we were reading... All injector values seemed fine at that moment. '17 Range Rover 5.0 Supercharged AB (Sold)
'03 BMW E39 M5
'01 BMW E46 M3
Post #253460 9th Apr 2014 10:09am
RRD
dealer time
I'm not fond of random replacing stuff and hope the problem goes away. It gives both faults on rail pressure sensor and fuel pressure sensor (I believe fault code 089 and 190), so the car just doesnt get enough fuel every now and then. I don't think the sensors are faulty...
Problem is the car can drive for 100 km without any problems. I'd rather just see it stopping completely, that would make fixing a lot easier. '17 Range Rover 5.0 Supercharged AB (Sold)
'03 BMW E39 M5
'01 BMW E46 M3
Post #253461 9th Apr 2014 10:12am
