![]() | Home > Technical (L322) > Diesel Heater smoking. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Mine does it occasionally 2012 TDV8 Vogue (L322) |
TST717 Member Since: 18 Oct 2014 Location: Inverness Posts: 35 ![]() ![]() |
My D4 does it although the RR 405 doesn’t ..!
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 ![]() ![]() ![]() |
It seams to be loads better ,maybe because it has not been used for a while,thanks for the replies. Mercedes AMG w207
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Need to replace a burning chamber.
Is a smoking FBH bad ? 2012 TDV8 Vogue (L322) |
No its not. But it's progressive, the burner is full of soot and going worst and worst. Soon it may be that it won't fire up anymore. |
Can it be cleaned or is replacement the only option? 2012 TDV8 Vogue (L322) |
It can`t be cleaned. Its possible to replace evaporator mesh only, but for that you need to saw burning chamber apart and after replacement weld it back together. + new gasket 100%.
https://www.ebay.de/itm/134884795465
Thanks jaguar3 - great info as usual |
