![]() | Home > Technical (L322) > Accidental Fix L322 Deployable Steps |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 676 ![]() ![]() ![]() |
Hi,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Or simply unplug the motor... Can't move that way |
Hi,
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 202 ![]() ![]() ![]() |
After posting on this thread 2 days ago, yesterday I noticed that the drivers step was still deployed when I came back to the car. I unlocked and locked again and the step retracted a little then stopped and deployed again. I got in the car and the step didn't retract. I drove home and before I got out I looked out the window and the step had retracted. Opened the door and it deployed. Locked the car and it snagged and deployed again. I can't see anything physically hampering it. When the weather improves I will give the moving parts a good clean and lubricate them with some moly grease.
Hi,
Thanks for that advice Andyroo. Definitely will give that a go.
th3chainrule Member Since: 24 Sep 2022 Location: East Posts: 16 ![]() ![]() |
What jack do you use on your vehicle? |
Hi, I use a full size trolley jack @ home, but in the car I keep a bottle jack. Fuji White / Jet 2012 4.4 TDV8 Westminster |
Yeah, I have a trolly jack too but im concerned that it wont clear the step if it is deployed. Thinking I need to by a bottle to jack the car if I dont take the steps off like you did. I'm too chicken to jack the car from the under the step with the trolly jack. |
Hi, I have a bottle jack as well but it wouldn't fit under the sill if you had a punture even in off road mode.
I lock the steps out or else leave a door ajar and use a trolley jack with one of these big rubber blocks between the jack pad and the jacking point. Rubber blocks like this Amazon one
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
I wish this accidental fuse fix would work for me! I got my steps working for about a week or two after purchase but then they seized up again. When I took them off the arms had seized and on closer inspection the motor housing had failed and water had gotten into the electrics.
