Home > Technical (L322) > Airbag light on dash?
PJS
Hi everyone,
On saturday a red light came on in right hand corner of the dashboard (a seat, with a seatbelt going across and a small circle)
The book says its an airbag fault, and would be best to take it to the stealers to have a look.
I've rang them, and they said its £110 to put it on the diagnostics to try and find the problem, and then expense on top to actually fix the issue.
Any advice guys? Should i just leave it as it is?
Regards, Peter.
Post #68379 13th Jun 2011 12:25pm
As from next year it will be an MOT failure
Post #68380 13th Jun 2011 12:28pm
pretlove
mine has came on since doing my paddles i just need to turn it off now Sad "RANGEISM WILL NOT BE TOLERATED"
Post #68385 13th Jun 2011 12:46pm
peter, it could be the airbag sensor under the seat cushion, its worth checking the connections under the seat first..my passenger seat had this problem and replacing the seat sensor solved it..
Post #68388 13th Jun 2011 1:39pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Fingers crossed its a dodgy connector, however it may be more serious, take a look at my airbag warning light experience.
http://www.fullfatrr.com/forum/topic5533.html
Thankfully it's all sorted now.
Gone - Range Rover Supercharged 2006
Post #68390 13th Jun 2011 1:58pm
