![]() | Home > Technical (L405) > DIY Oil change on SDV8 reveals underfilled or burning lots |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
Are you using a vacuum pump or draining from the drain plug? 2018 SE SDV8 4.4 Byron Blue |
Geo Member Since: 04 Apr 2023 Location: South East Posts: 16 ![]() ![]() |
Drained down from the sump plug. |
Check to see if there is a blockage, could be a lot of carbon gunge etc do you have a boroscope?
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 371 ![]() ![]() ![]() |
Wow, that is a lot of oil. Unlikely to have used or leaked 6 litres I would have thought. I regularly check the oil in my cars so that I can establish how much is being used (if any) and how often it needs topping up.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
3 litres? Cant be. Does the oil level sensor work now? overfinch modified |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
Did you remove and drain from the turbo return reservoir drain plug? |
Didn’t drain down turbo reservoir. How much would be in there?
That you put in 9.2L to get to the correct level shows that you didn't just drain from the turbo reservoir drain plug. |
Do you have oil in the cooling system? 2018 SE SDV8 4.4 Byron Blue |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
Check the oil filter drain leaf spring is on it's post and not loose in the bottom of the filter housing. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1394 ![]() ![]() |
I can't believe that you weren't having overheating issues or low oil pressure with only 3lt of oil in the system.
No oil in the cooling system.
So all the basic possibles covered, lets hope its not the turbo's seals leaking etc burning the oil off.
