![]() | Home > Technical (L405) > Ghosts in the machine? WTF? |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1889
Not ghosts, merely Gremlins……. |
| Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 68
Hi, apologies for hijacking thread..I may have similar issue (maybe the battery again) I have Key not in the vehicle or screen rebooting and couple of time the car turned itself off when stopped at traffic lights with Start/Stop active.
| ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 284
I would suspect that the battery would be classed as a consumable item and therefore not covered by warranty but it all depends on who is providing the warranty I suppose.
| Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 120
Are you testing the battery directly, or via the under bonnet terminals? Maybe it’s an earthing problem. A common fault are the earth straps behind the splash guards 2017 (67) Vogue SE Corinthian Grey |
To be honest I am just doing some DIY sleuthing and taking the readings from the iCarSoft tool so I probably should get it properly checked. I think they should make it compulsory that you have to have a licence to buy an ODB scanner so that amateur numpties like me cant go about giving myself nightmares by looking at things that should be left to those that know! |
| Kev the Rev Member Since: 07 Jan 2024 Location: Ripon Posts: 45
Have you checked the earth connection inside the wing. Have a look on YouTube to see where to look |
Good point, that is the inside the drivers side wing? Prone to corroding and breaking by the looks of it. I will give that a look next. |
| Malbro Member Since: 22 Mar 2023 Location: Cumbria Posts: 17
Another vote for wheel arch earth points. I had it on my list of things to check as part of a preventative maintenance job on my 2016 AB when I got several random messages along with a flickering passenger side headlight. Checked passenger side earth and it came off in my hand! |
Just for my understanding, on the L405 are there earth straps on both sides of the car, inside of the wheel arches? I thought there was just the one on the drivers side that was prone to corroding? Is there one on the passenger side as well? |
Both sides.
Looks like this will be my weekend job then. I take these are relatively easy to remove, no special tools required? |
No you’ll have them off in a few mins, and then how long it takes depends on what you find in there.
Do the wheels have to be off to get the splashguards off? The jack I have wont lift my RR and would rather not have to buy a new one for a couple of weeks if I can help it? |
| All times are GMT |
