![]() | Home > Maintenance & Mods (L405) > 2 Tonne or 3 Tonne lifting capacity & stands? |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
I cant really answer the question properly, but I had a 2T trolley jack bend and buckle under my L322.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 380 ![]() ![]() ![]() |
Get a 3 tonne one…your life is worth it! Same with axle stands get 3 tonne ones remember the old adage better safe than sorry!
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 153 ![]() ![]() ![]() |
I have a 4T two post full rise lift. If you have the space then a 2 post or scissor lift is the safe and comfortable way to go and most RR owners can afford the £2k to £5k install cost. That's only about 3 to 5 RR dealer services. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1803 ![]() ![]() ![]() |
3Te.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 677 ![]() ![]() ![]() |
Hi, I have 2 trolley jacks, a 3 tonne smallish one that I keep in the car and a full size 5 tonne high lift one with a removeable cross beam attachment for major works, get a quality one with a wide base for added stability.
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
I agree with the guys. Always go bigger. We buy these big heavy cars, always better to have bigger kit that is over spec rather than on spec. 3-6 Tonne axle stands at a minimum and 3-5 tonne Jack. If you havent seen the below video by project farm although he is testing US branded axle stands its something everyone should watch.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 217 ![]() ![]() ![]() |
I have 2, 3ton bottle jacks, as mentioned above using a single bottle jack can be a bit too interesting, the vehicle has to be lifted quite high and leans alarmingly on the small footprint. Using 2 jacks makes it more to my liking, but a 3 ton trolley jack is definitely the way to go. SGS regularly do bundled jack & stand deals, good quality kit IMO.
Not only you, I always put the wheels under too! |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Use a 3 tonne trolley jack, and then minimum of two 3 tonne axle stands. If I take off both front wheels, I use three axle stands.
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 288 ![]() ![]() ![]() |
I’ve used this jack successfully https://www.costco.co.uk/Tyres-Automotive/...U/p/254971 2016 SDV8 AB |
RDR Member Since: 05 Sep 2014 Location: Derbyshire Posts: 279 ![]() ![]() |
I have two decent 3ton trolley jacks in the garage and a 2 ton which feels bit sketchy for a Land Rover . I also a have a power built jack which I find works brilliant
RDR
It is good, nice and sturdy and lifts very high the ratchet clicks in as you go up which is great and to lower you just bump it up a bit release the safety and lower on the bottle jack.
Thanks for the link RDR, that was very good of you. Ill definitely be adding these to the workshop before I get my 2 post lift. Current yokes
