Home > Maintenance & Mods (L322) > New member / 2011 Purchase Advice Rusty Arches
FFRRrob
Hi All!
A Galway Green 2011 4.4 has become available but I’m concerned by the rear arch lip rust.
Is there any saving this or is it too far gone, despite the quite good price on the car?
The car is a short flight away a so is it worth it…
Sorry these are screen shots from video so not amazing quality…
Any advice would be much appreciated!
Thanks
Post #684348 30th Jan 2024 8:34pm
DrRob
You posted twice Very Happy
https://www.fullfatrr.com/forum/topic69098.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order.
Post #684362 30th Jan 2024 9:58pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Perfectly normal for the age of the car. You won't find one without this. Just slap some Hammerite over it and forget about it. The door seal covers it anyway. You should be more concerned about rust on the tailgate or about the (visible) rear arches. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #684371 30th Jan 2024 10:51pm
Check behind the plastic Sill covers sir... Whistle
Post #684384 31st Jan 2024 1:54am
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I've just had the welding done on mine and the arches were sanded back and finished with stoneguard.
Thinking being that if they start bubling again I can rub back and refinish at home.
With regards to the plastic covers that @cam-tech-craig mentions, the drivers side on mine was the worst.
Which when prepped for welding became this.
But all fixed now and treated with Lanoguard. ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2021 BMW iX3
Post #684399 31st Jan 2024 10:51am
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
guys
Just regarding a paint for these repairs I would highly recommend Rust Bullet. Its a Rust inhibiter and primer, it can be painted over or have a second layer of UV protected coating put on it. It will stop the rust from spreading. Im sure there is a UK distributor but it is the best thing you can use to underseal a car also. Current yokes
2012 4.4 TDV8 Westminster
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #684407 31st Jan 2024 11:41am
BAZ8046
As has been said they all suffer on the edge of the arch so I wouldn't worry too much.
Hopefully behind the sill cover is ok as this is where they can start to go.
Mine is a 2012 and wasn't too bad but glad I caught it when I did.
I used POR-15 and then a coating of Dinitrol 4941 over the top and their ML cavity wax in the sills.
Hopefully it will be ok for few years.
 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #684423 31st Jan 2024 2:26pm
