Home > Maintenance & Mods (L405) > Addition to low beam headlights
Page 2 of 3 <123>
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
I only asked because it is very dark at night where I live, with a lot of wildlife jumping about
๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚
did not mean to upset anyone
Post #684375 30th Jan 2024 11:15pm
Tis very dark where I live (edge of the cotswolds) and I fitted a lightbar behind my grille... Helps tremendously. Ive also fitted a can-bus relay so it only comes on at speeds above 50mph Thumbs Up
Oh and to all you LED haters! Technology moves on! 2012-2018 L405 headlamps are dreadful Fact! These can be improved by retro fitting NEWER technology... Simples Thumbs Up
Post #684380 31st Jan 2024 1:06am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
FYI Craig I'm not a "LED Hater" (after all only 2% of my lighting spread over my home, workshop & office is non-LED and they are in places like loftspaces & storage cupboards that are rarely acessed so not cost effective to replace until they fail).
What I am against is people that seem to know better than lighting engineers fitting bulbs/lamps/globes into equipment not designed for them in the first place. Even people who otherwise appear to be generally intellegent seem to ignore this fact.
Current lighting fitted to vehicles within the contraints of the stylists has not moved on enough. Yes, technology moves on, but they never seem to perfect each stage before making it available or moving on to the next (look at phones - 3G, 4G & now 5G -whats the betting they will be looking at 6G before we have decent 5G coverage - as an aside, I don't care how many G's my phone has - I just want it to work !)
I would respectfully suggest that people who don't find glare from oncoming vehicles with LED lighting an issue get their own eyes tested (maybe to vocational drivers standards).
Post #684476 31st Jan 2024 11:15pm
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
Like Craig, I also fitted a light bar behind my grill on my 2016 FFRR. It made a massive difference to the poor standard lighting that the car came with. I also agree upgrading the bulbs is another good option. However, LR clearly realised the lights were poor and the ones on MY2018 are so much better.
 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #684498 1st Feb 2024 10:26am
Gremlin500
Not really wanting to enter into the fray, each to his own, but:
I found the OEM L405 HIDS to be inadequate at much less than the speed limit on unlit country roads as Stan has said. (As we get older, our night vision deteriorates, and what is fine for someone in their 30โ€™s or 40โ€™s may be insufficient for someone in their 60โ€™s or 70โ€™s).
I hate glare and have no wish to annoy others by driving at 30mph in a 60 limit either, so when I fitted my LEDs, I carefully checked them as a pedestrian from about 100m away on a level road, there was no glare, the beam has a very distinct cut-off, I assume due to the projector design, which was introduced to better control the light pattern of the then much brighter HID bulbs replacing the old yellow filament bulbs, and to minimise glare.
As others have said, the same lamps when installed in reflector headlamps will light up the sky in all directions causing glare, and so will light bars, which are illegal on the roads.
Good sense should prevail IMHO, itโ€™s easy to check your own car for glare, then act appropriately.
Unfortunately, nothing is idiot-proof. V6 Vogue - โ€œLess is Moreโ€ - less to go wrong!
Post #684510 1st Feb 2024 12:12pm
kevinp
Well said Gremlin. I've just put some led's in my L322 and replaced just one side and looked at them from a distance just to check there was no glare compared to the standard bulb. Besides the LED being brighter it was fine.
Post #684514 1st Feb 2024 12:41pm
SamThomas
Maybe if you cleaned the existing lights you would have better night vision !
Post #684517 1st Feb 2024 1:14pm
SamThomas
It does indeed, but that's no reason to cause discomfort to others.
Again, I respectfully suggest that people get their eyes tested............
(I note that no-one seems to comment on this issue).
Post #684519 1st Feb 2024 1:19pm
SamThomas
When I had a L322 I never, ever thought that the dipped beam was inadequate. However, all parts of the lights were maintaned/cleaned correctly/glass polished (with no damage) & new standard bulbs/lamps/globes fitted (one was deffinatly on the way out when I bought the car).
Then again, I have my eyes tested annually for my HGV licence (to a higher standard than required for a car).
As it happens, I find glare an issue from further, rather than closer distances.
Post #684521 1st Feb 2024 1:27pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
I agree people should have regular eye tests, but...
...has *your* ophthalmologist found a way to fix the natural deterioration of night vision? If so, please drop me their details. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #684523 1st Feb 2024 1:42pm
keep it on topic please.. ... - .- -.
Post #684535 1st Feb 2024 3:19pm
SamThomas
With respect Stan the subjects of LED headlamps & vision are very closely related.
Post #684598 2nd Feb 2024 10:44am
the original post is about fitting a lightbar or similar to increase front illumination.
if you want to talk about visiting specsavers then start a new thread in off topic. ... - .- -.
Post #684601 2nd Feb 2024 10:51am
SamThomas
Good idea Stan, I'll start a new thread that will discuss eye tests/aging eyes/night vision & the way LED headlamps, (both OE and conversions) cause glare.
Similar to this one.........
Post #684662 3rd Feb 2024 11:35am
supershuttle
I posted earlier, I have an early l405 and the lights are definitely not as bright as my previous L322s but they are adequate and much better than some other cars I drive. I'm over 70, wear glasses and I don't really like driving at night anymore (regardless of how bright my lights are) as I am often dazzled by oncoming traffic. I talk to others younger than me and they have the same problem, obviously they must have because I am significantly higher up in the Range Rover. Oh to keep on topic if you want a light bar just fit one, those that have them seem pleased, going off topic slightly if you want LEDs just fit them - like many others I just get used to being dazzled and get over it - life's to short. Geoff
Post #685851 17th Feb 2024 11:58am
Page 2 of 3 <123>
