Home > Technical (L322) > Strange smoke
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Strange smoke
Had my car about 18 months now. Work van got stuck in the verge outside so I pulled him out. First, I had it in low range (first time ever) and when I was sat still there was a lot of strange smoke coming from underneath. Switched to high range and pulled him out and the smoke disappeared. Any idea what it was/is? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #684937 7th Feb 2024 11:47am
Dolphinboy
could have been the FBH kicking in?
Post #684986 7th Feb 2024 7:53pm
tymh
To my knowledge, I haven’t got one. Tym
Post #684987 7th Feb 2024 7:54pm
mjdronfield
I think all diesels have one. It might be the extra fob for remote park heat that you haven't got. The FBH exhaust is down near where the passenger side front mudflap is or would go, if that’s the vicinity you had the smoke from.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #685002 7th Feb 2024 9:20pm
tymh
Not sure, I just know there are as smoke coming from under the car! Switched to high range and it stopped. Tym
Post #685003 7th Feb 2024 9:22pm
DrRob
Maybe the motor for switching ranges was burning out due to lack of use? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #685011 7th Feb 2024 9:44pm
tymh
It switched range ok. The smoke happened after I’d tried to pull the van out. Switched to high range, continued to pull him out (successfully!) and there was no smoke whilst in high range. Tym
Post #685012 7th Feb 2024 9:46pm
DrRob
Keep driving and ignore it Rolling with laughter
I bet it was the FBH Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #685041 8th Feb 2024 9:38am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, might be oil seeping down. I had it intermittantly when I went in reverse it would drip onto the exhaust silencer, fine going forwards, you may have doslodged some in your to & fro stuff.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685050 8th Feb 2024 10:19am
JayGee
FBH, oil and electrical all have very distinct smells so this would be the obvious way to tell. 2012 TDV8 Vogue (L322)
Post #685054 8th Feb 2024 10:32am
tymh
I didn’t smell anything, just saw the white smoke. Tym
Post #685055 8th Feb 2024 10:33am
JayGee
If it's oudorless it's likley coolant as difficult not to smell smoke in that area as it gets drawn into the cabin from the top of the bonnet. 2012 TDV8 Vogue (L322)
Post #685061 8th Feb 2024 11:10am
AndyRoo
Yes, agreed, see if you can smell it next time, could be anything from coolant spillage to an insulation short, each has a very distinctive smell.
Could be nothing, could be about to catch fire.
Otherwise we're really just guessing. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685063 8th Feb 2024 11:19am
tymh
I suppose I’ll just have to try it again! Tym
Post #685064 8th Feb 2024 11:20am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Don't forget to turn camera on and keep extinguisher close. Just in case Wink
Post #685071 8th Feb 2024 12:00pm
