![]() | Home > Technical (L405) > Oil dilution due to dpf and subsequent engine failures |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 701 ![]() ![]() ![]() |
Hi, I've not experienced this on my FF but it did become quite a problem on our Mazda, that used regen on the exhast stroke and it became so much of a problem that the sump would fill up with diesel.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1875 ![]() ![]() |
I'd like to see the technical data they used to back this up, before taking it as gospel... |
Hi, there seems to be some folks who are thinking fuel in the oil is down to failed DPF regenerations, this is not true, fuel gets into the sump during the exhaust stroke regardless of whether the regen is successful or not as the DPF is downstream of the exhaust port, i.e. the diesel (or most of it) has already passed through the engine before it reaches the DPF.
Hi, thanks for the explanation, every day is a school day |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409 ![]() ![]() ![]() |
How do the engines test for oil dilution?
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1852 ![]() ![]() ![]() |
Hi Zebedee,
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 150 ![]() ![]() ![]() |
I don't understand how you can over-fuel a diesel. They always run excess oxygen, so any excess fuel will just burn and deliver horsepower?!?!
Hi ChrisJC,
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1433 ![]() ![]() |
From WSM but note this 7% mentioned below, was increased to 10% by JLR for those who had the software update (due to customer complaints regarding increased frequency of service alerts). And I guess already installed for newer cars dated after that bulletin? Engine oil dilution can occur due to small amounts of fuel entering the engine crankcase during the post-injection phases. This has made it necessary to introduce a calculation based on driving style to reduce oil service intervals if necessary. The driver is alerted to the oil service by a message in the IC. The DPF software monitors the driving style and the frequency of the active regeneration and duration. Using this information a calculation can be made on the engine oil dilution. When the DPF software calculates the engine oil dilution has reached a predetermined threshold (fuel being 7% of engine oil volume) a service message is displayed in the IC. Depending on driving style, some vehicles may require an oil service before the designated interval. If a service message is displayed, the vehicle will be required have a full service and the service interval counter will be reset. 2018 SE SDV8 4.4 Byron Blue |
Here https://www.fullfatrr.com/gallery/albums/u...ration.pdf 2018 SE SDV8 4.4 Byron Blue |
Interesting - thanks!
For those who are interested, a little light reading:
Thanks Kot! |
My God you must have good eyes |
