![]() | Home > Technical (L322) > Steering Lock - L322 2010-2012MY |
gm0rdi Member Since: 19 Jan 2022 Location: Hawick Posts: 15 ![]() ![]() ![]() |
[TLDR] Looking for someone who understands in detail the steering lock ...
I wasn't expecting ... I was hoping ... ![]() From what I've seen it isn't at all clear that the motor on that thing runs bidirectionally. Given there's no apparent way for the polarity to reverse, my supposition is that it runs in the same direction to both lock and unlock for a specific duration, defined by signals from the CANBUS. Me being a software engineer of advancing years, that's how I would have done it given the wiring structure that is *apparent* from the diagram. Of course, the reality might be somewhat different. What would be helpful would be if I could find someone nearby who has a steering column off of the car that I could test my theory against. But that ain't gonna happen, I don't suppose.
Fortunately it is actually parked parallel to a wall rather than "nose in" and access to the front isn't a particular issue. For interest, I'll try to include a picture of its current position. It is facing away from the exit, and you can see the height restriction that will prevent a transported getting to it on the right hand side of that. I hadn't considered the "dollies" approach, but that's a helluva good call on your part. Appreciate it! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2727 ![]() ![]() |
It's very easy with electronics to reverse the current flow through a DC motor to change its direction. As an example, the AFS headlamp module sends commands to the headlights via a LIN wire to raise, lower, move left and right. |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 798 ![]() ![]() ![]() |
DON'T go busting your steering lock just to overcome this (short-term) issue!!! |
You are indeed a legend in your own lifetime - bravo! Neither of us need go that far; ultimately I will dump this in the hands of the AA (with whom I have "everything under the sun" coverage included in my bank account benefits). The major difficulty is one of timing; the repair shop it is destined for (central Edinburgh) can only take it on a specific day three weeks hence, and getting recovery to coincide with that most likely is actually the remaining hardest part. Notwithstanding all that, I'm really curious to do as much as I can in the "self help" department - you never know, I might actually fix it ![]() So I'm going to probe the various BUS lines with a scope and try unplugging stuff to see what happens. Again, the hard part of this is going to be locating the various modules. I need an Idiot's Guide to L322 Module Locations (me being an idiot!) All the best!!! |
I *TOTALLY* get that, just as long as the physical implementation isn't that of the simplistic schematic in the workshop manual. For instance, if the -VE side depicted really is "chassis grounded" that that's not going to happen. If both lines of this are fed from (say) the BCM then it is trivial to do as you say. Mostly this question is now moot, I think - thanks to your idea of the "dollies". I'd still like to understand exactly how it is implemented, though ![]() Cheers! |
Perhaps a silly question - have you done a hard reset by disconnecting the battery and touching the +ve & -ve cables together? The older I get, the more I realise that people confuse wrinkles for wisdom |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 189 ![]() ![]() ![]() |
it is implemented this way, power and can bus are connected to the control bord. and putting reverse polarity will fry board or whole can bus. Good luck.
Nice. That's not at all what I said. But thanks, anyway ... |
if fuses are ok fixing rest issues without knowing DTCs and without diagrams is wasting of time. Diagrams you will find in wiki. Or pay few £ and download from topix. |
Again: you REALLY haven't understood what was being asked for (unfortunately). In respect of the steering lock, all I was looking to do was to disable it temporarily so the car could be moved a few feet to where it could be loaded onto a transporter and taken to a specialist to have the actual fault(s) repaired. We're now done here. |
before you ve got answer - you need physical access to steering motor to unlock or you need to fix immobiliser passive module. to unlock wheel. You trying to harm yourself badly, and when you get answers you don't like, because are not optimistic to your idea you asking again.
Red Desert Member Since: 15 Apr 2012 Location: Lake Constance Posts: 20 ![]() ![]() |
I mean that Mr. Grafe from m1n1.de just had a customer with the same problem and was able to solve it. I would just write him an email |
