![]() | Home > In Car Electronics (L405) > End of 3G |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 235 ![]() ![]() |
Traffic sign recognition is from a combination of the navigation map data (loaded via USB) and the forward facing cameras by the rear view mirror, so not affected by the loss of 3G.
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 261 ![]() ![]() ![]() |
Can’t find mention of a specific TCM, could be a function/piggy back on the nav control unit which is a cool £1200 part.
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 66 ![]() ![]() ![]() |
So does the MY18 cars have the compatible kit fitted? |
Yes, 2018 on is 4G compatible. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1822 ![]() ![]() ![]() |
5G dongles are now available, but the price is a bit steep, -over £500! 😳 still nice to have 5G in your ffrr if you can afford it |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 684 ![]() ![]() ![]() |
Hi, although 3G services in the UK will terminate as mentioned above it is worth noting that 2G services will be maintained till 2033 at least.
Andy, is a 3G/4G SIM not backwards compatible with 2G anyway? V6 Vogue - “Less is More” - less to go wrong! |
Hi, yes, it should be for EE, i.e. if no 3G service available should default back to 2G, however, that's not going to work for H3G as they don't have a 2G network.
Thanks Andy,
chrisnj Member Since: 21 Aug 2017 Location: Surrey / North Somerset / Florida Posts: 60 ![]() ![]() ![]() |
Now the 3G network is switched off for most providers is there any update on this? Specifically interested in those of you that have the 2017 SVA's or similar with the updated upper Infotainment screen. As I understand it although they updated the infotainment for MY2017 the SIM modem was still only 2G/3G and it wasn't until the MY2018 updates where the lower touchscreen was added that a 4G modem was also added. Is this correct?
Dunc1955 Member Since: 06 Mar 2022 Location: Seaham Posts: 7 ![]() ![]() ![]() |
My 17 build 18 reg car has an EE 4G sim, remote and everything else works fine. It has a full MD service history but unable to confirm if it was due to a software update. |
Misha Member Since: 27 Dec 2023 Location: Boulder, CO Posts: 19 ![]() ![]() ![]() |
I have a 17, and everything works out here in Colorado. |
Big Vee Member Since: 27 Dec 2023 Location: Lancashire Posts: 21 ![]() ![]() ![]() |
my 20 build has a Three data sim, out the other day and this was showing 3 & 4g |
Markw Member Since: 19 Sep 2023 Location: Tyne and wear Posts: 5 ![]() ![]() ![]() |
any new updates on this
