Home > Technical (L322) > Fault codes after new alternator.
Luma
Australia 2012 Range Rover Vogue SE TDV8 Alaska White
Hello RR boffins,
I recently had an alternator fail and saw all of the modules/computers shutting down as the battery limped us home.
its a 2012 4.4 V8 Diesel.
After fitting the new alternator, the car runs perfectly, charge is at very steady 13.4v under all loads, but after running for 20-30 seconds, I get the charging system fault indicator on the dash.
It disappears each time I restart the car and comes back shortly after.
No engine light, just red asterisk and battery symbol on the dash.
It does not seem to log any codes, unlike when the alternator failed when it logged the DTC and instantly put the car into restricted performance mode before the engine was running.
I believe this tells me that the sense wire is ok, just not sure why the delay and alert.
I have now also noticed that the seat fans immediately stop once the warning comes up on the dash. Everything else still seems perfect.
Has me very confused.
Post #685819 17th Feb 2024 7:13am
PeteT80
Was it a Denso alternator you fitted?
Post #685830 17th Feb 2024 9:22am
Luma
Yes, Denso alternator
Post #685832 17th Feb 2024 9:33am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Charging voltage should be more like 14.8v
Post #685839 17th Feb 2024 10:35am
Luma
OK, Update.
16hr drive and the voltage was locked on at 13.4v
Checked the earth - all good
NO voltage between negative battery terminal and engine block.
checked fuses - all ok
Disconnected Negative battery terminal for 2 hrs. - no difference.
the ONLY system that is not functional when the charging fault shows is the heated/cooled seats.
Everything else works.
Any ideas why the new alternator is only charging at 13.4v ? Is this software controlled ?
Post #686269 23rd Feb 2024 11:12am
aids22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Rimini Red
Yes the alternator is software controlled.
It may discharge when at a steady speed or accelerating and charge hard when decelerating
I think it works a bit like a hybrid car by recovering braking into the battery.
So your charge should not be at a steady 13.4v
You could try telling the car it has a new battery fitted.
Post #686276 23rd Feb 2024 12:02pm
Luma
can this be done without a plug in tool?
otherwise, I will have to organise a visit to the specialist.
Post #686277 23rd Feb 2024 12:16pm
aids22
Needs a tool.
The Gap IID Tool is a good investment
Post #686294 23rd Feb 2024 4:17pm
