Home > Maintenance & Mods (L405) > SMOKE & FUMES STILL after oil cooler changed!!…
Page 2 of 3 <123>
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys I was told the garage that was replacing the oil cooler that the connector had broken that goes into the thermostat housing very common for these to break could not get the part you are on about or the just the pipe either so we ordered a different part cost £10 and took the connector off the end job job. I have not been losing any coolant so doubt that the intermittent smoke and fumes I am still getting is related to anything coolant so check with the garage that has your car and ask them to replace the connector as you don't need the whole housing or the pipes that sit on top of the thermostat housing. I have spoken to a number of companies who are now thinking of having this crappy connector manufactured on its own as its this that perishes causing the issue.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #661208 6th Apr 2023 2:08pm
Geo
Glad to hear you got it sorted Jay, an independent solution is often the best way.
Mine is under LR extended warranty, common sense says take the RR away, but I'll wait until the job is completed now as the coolant loss could be a whole can of worms based on what I have now seen, which I'm told applies to all SDV8's.
Here is hoping the parts come in soon! Confused
Post #661228 6th Apr 2023 4:16pm
Geo
Out of interest are you still running the RR as a daily? Any issues cropping up (beyond topping up).
Marcel M6 wrote:
Quite a few of us waiting for that part - earliest I've seen quoted for availability is end May!
Post #661230 6th Apr 2023 4:19pm
jaysta10k
Hi Geo I am running it daily yes about 50 miles a day so obviously the smoke and fumes I am still getting can not be related to excess oil still burning off from oil cooler change as this should of all well burnt off by now. I am not losing any coolant so we have no idea where the smoke is coming from and its intermittent which is the annoying thing! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #661347 8th Apr 2023 1:10pm
Geo
Agree it’s the intermittent stuff that is most tricky. Good luck sorting it.
Post #661600 11th Apr 2023 2:46pm
jaysta10k
Explored every avenue trying to get to bottom of this intermittent smoke at back of engine and fumes oil cooler changed o rings changed at turbo feed pipe all pipes checked around donut jubilee clips all good no split pipes etc... any more ideas anybody. We did notice a small amount of oil around turbo nothing major possibly an oil leak from turbo could be culprit when its hot causing smoke fumes.
Cheers
Previous Cars
BMW M3 Carbon Black
Post #662433 21st Apr 2023 10:22am
DrRob
Has James Henhsall at Henshall Engineering taken a look at it for you? He's very good and in Cheshire hence the recommendation. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #662440 21st Apr 2023 1:32pm
jaysta10k
Hi @Drrob thanks for this I will contact James next week fingers crossed. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #662456 21st Apr 2023 4:46pm
RRL405
Greece 2014 Range Rover Autobiography SDV8 Santorini Black
Same situation as @jaysta10k
Hey Jay,
Were you able to have it resolved? What was it?
I have the identical problem as you. It all started a few days after an oil change at the Land Rover service shop. Forceful white smoke coming from around the rear of the engine and until the oil filter section. Had the oil cooler replaced as apparently that was the issue. Nothing changed, same smoke.
Could it be that the technician put too much oil in the oil change ant its leaking from some over flow tube onto some part of the hot engine? Could it be an overflow of turbo oil also leaking onto come part of the engine?
I had the entire engine cleaned with degreasing soap and had the car lifted up without the skirts and also cleaned with degreaser soap and a pressure washers trying to spray in all possible cavities between engine parts. After 4 days same smokey situation.
Any help?
Post #686150 21st Feb 2024 5:39pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
How is your coolant level, is it staying stable or has it dropped? Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #686165 21st Feb 2024 10:01pm
RRL405
Well its been in for the typical oil change and I have not checked since. But the smoke is more of a burnt oil smelling smoke. What ideas do you have about the coolant? Also the smoke comes from the part of the engine that is against the firewall, are there any coolant lines back there?
Post #686169 21st Feb 2024 10:26pm
jaysta10k
Hi this really is a strange one I had no more smoke and fumes due months then suddenly got that dreaded smell on cabin again don’t know whether it was a coincidence but I’m sure the car was doing a DPF regen so I am now going down this avenue of investigation. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #686174 21st Feb 2024 10:55pm
RRL405
But if it smokes that often, every few rides or every ride is it normal to do a DPF regen that often too?
Also, how could the DPF regen generate that smoke in that area of the engine?
Post #686186 22nd Feb 2024 8:02am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Jay,
Have you checked the rocker gaskets? My V8 Merc leaks and I get similar symptoms to yours.
Post #686210 22nd Feb 2024 12:58pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
When I had my leaking oil cooler replaced, straight after and quite randomly there would be mysterious plumes of grey smoke appear out from under the bonnet. It didn't seem to be related to engine incline or even movement, I was sat at the lights and a lot of grey smoke belched out around the bonnet.
The Independent who fitted the cooler said it is impossible to get all the oil spilled when changing the cooler off the top of the engine so it'd work its way out eventually. After 3 weeks, there were no more grey plumes.
Post #686219 22nd Feb 2024 3:03pm
Page 2 of 3 <123>
