Home > Technical (L322) > Lack of Brake Assistance
dhallworth
I got in the SC tonight, started it, put it into D and noticed that whilst my foot was giving the normal pressure on the brake pedal it started to roll.
I pressed the pedal harder and realised that it took a lot of effort and the pedal was rock hard.
I gave it a second or two and the pedal felt normal again and the brakes were fine. I’ve noticed that when driving if you pump the pedal 4 or 5 times it gets hard again with minimal travel and requires a lot of effort to slow the car.
I know there’s a separate vacuum pump on the SC and that there’s a vacuum line from that into a T on the pipe that goes into the servo but I’ve not had chance to look where the other end of the vacuum pipe is attached to this evening.
Has anybody else suffered from something similar or know where would be a good place to start looking?
Thanks,
Post #606615 16th Sep 2021 9:30pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
David, did you get this resolved? Have a similar problem which is getting alarmingly worse. Don't appear to get servo assistance upon start up, for a short while, then kicks in as normal.
John Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #686244 22nd Feb 2024 10:11pm
dhallworth
I found I had a small vacuum leak. Sorting that out cured the issue.
I can’t remember where it was now though I’m afraid.
Post #686247 22nd Feb 2024 11:40pm
appj62
Wondering if I disturbed anything when I changed thermostat. I'll have a root around. Previous cars:
Galaxy 2001-2007
Fiesta 1984 - 1987
Post #686265 23rd Feb 2024 10:35am
