![]() | Home > My Range Rover > My first Range Rover some advice please |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Heated seats can take a while to get up to temperature on some motors Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Some towbars can be a pain to remove if they’ve been on there a while due to rust. Just a heads up |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 154 ![]() ![]() ![]() |
Thanks, should there be anything under this cover on the passenger side of the boot?
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Security wheel nut |
Thanks, is that all? |
Nothing in mine. Replace all locking wheel nuts with normal ones. You’ll thank me at 2am in the wet on the side of the motorway when the locking whee nuts strips. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks, where is best to buy 4 standard wheel nuts or are they best purchased from the main dealer? |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 138 ![]() ![]() ![]() |
I wouldn't do that. They'll happily sell you the LR badly designed product for which the heads will swell upon corrosion induced by moisture ingress.
Thank you that is a fantastic in-depth reply very much appreciated |
Buy 20 new ones and replace all in one go. You are then starting from new. As above, all nuts swell |
Would these stainless one be a good buy?
I can't tell from the mobile app listing which version these are. So cannot say if they'll fit your car.
Maybe these ones in that case?
Looking at the eBay item description, the seller says "For Range Rover 2001-2012".
