![]() | Home > Technical (L405) > heated seats |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 252 ![]() ![]() ![]() |
I don't find mine particularly hot (MY17). My L322 was much hotter - perhaps you have an issue?
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1081 ![]() ![]() ![]() |
Compared to my L322, the seats in my car don’t get as warm, nor do they cool as much. If your’s are getting too hot, I’d say there was an issue with them, but being an electrical ingoramus, I couldn’t say what it might be. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
Thanks all , i,m sure they cant be right. overfinch modified |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
I think you're right, I have mine on pretty much all the time (lowest setting) and find them comfortable. Geoff |
The thing is does anyone know what can cause this? I cannot have them on anything but the lowest setting and even then I have to turn them off , will have to check passenger seat also. overfinch modified |
i guess theres an ECU or some kind of regulator/temp sensor that might be faulty..
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 180 ![]() ![]() ![]() |
I seem to have the opposite issue. Unless my seats are cranked up to max I can’t feel any heat. Even on max it is just about warm and not hot. My previous cars (BMWs) were all capable of giving third degree burns. So interested to know if there is a temp regulator that may be causing my low temp and also the problem the OP is raising of too hot. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Mine are very weak too! |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
Same here, heating is very weak. Cooling is OK though and was very nice last year in the South of France. The heated seats of my wifes Freelander 2 are much better at heating.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
I have a 2015 L405 Autobiography. You have the heated and cooled seats (heated and cooled use a different system to heated only), the seats will cook you if on setting 3. I'd consider this perfectly normal and the sign of a healthy peltier cell.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1504 ![]() ![]() ![]() |
Mine are roasting hot same as steering wheel, I have no complaints on mine |
I thought something was wrong as these seats are much hotter than on all my previous Range Rovers and the steering, but obviously, there is not a problem as others also have seats hotter than their ovens.
Toasty testicles hot |
