Home > Maintenance & Mods (L322) > 2006 4.2 SC Battery Replaacement
Gibbs155
United Kingdom 2006 Range Rover Vogue 4.2 SC V8 Orkney Grey
Hi.
I’ve just bought a 2006 4.2 SC and need to replace the battery. The part number is LR180616 or YGD00271 and the original is rated at 110Ah 920cca and is a wet/flooded type. I am keen to change to AGM but am struggling to find an equivalent specification as mos5 seem to have a lower rating.
Can anyone suggest an alternative to the OEM battery or advise if LR original AGM batteries from a later model would suffice even if lower rated.
Thanks
Post #686354 24th Feb 2024 3:13pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
This the replacement battery that was fitted 6 years ago (its being replaced this year with the same).
I give it a top up charge every week as i dont use it much, and the recondition function few times a year with my C-Tek charger.
"Touch wood" still going strong Thumbs Up .
Post #686357 24th Feb 2024 3:24pm
RogueRanger
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I went on the Euro Car Parts site and bought a Bosch unit last month. It was £168. They matched it based on my reg number. It’s been fine since and the removal/replacement process took no more than 15 mins. Des
2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion
1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal
2010 Mercedes R230 SL63 , Tenorite Grey
Post #686368 24th Feb 2024 6:09pm
Gibbs155
Thanks. I’ve looked and can’t see a 110 Ah 920cca AGM battery so am going with an Exide 95Ah 850 cca AGM. The JLR OEM battery that I’ve removed was made by exide so figure it will do the job.
I’ll let you know how I get on.
Gap IIT BT inbound as well to see how many of the intermittent faults were down to the old battery.
Finger Crossed
Dave 2006 Range Rover Vogue 4.2 Supercherged
2012 Land Rover Defender 110 XS Utility
1980 Land Rover Series 3 diesel pick up.
Post #686491 26th Feb 2024 2:49pm
RogueRanger
Good luck! Des
Post #686514 26th Feb 2024 8:03pm
